HELP fast please!!
Old Oct 19, 2009 | 07:01 PM
fc3si's Avatar
AZ HELP fast please!!
hey i have an '86 rx-7 n/a.
i just finished troubleshooting and i've narrowed it down to the injectors/circuitry.
the fuel pump is new and when i open the air meter is sprays from the main fuel line.
but the injectors don't pulse???
what would cause this? and what should i check.
ALL the fuses are fine
thanks, Sean
Old Oct 20, 2009 | 09:18 AM
Aaron Cake's Avatar
Engine, Not Motor
Check the crank angle sensor.
Old Oct 21, 2009 | 03:41 AM
fc3si's Avatar
i checked it and the resistance was .161 on both sides of the clip.
how can i test the actual injector?
i have the primarys out right now.
the clip voltage for them changed when i tapped the ground against the bell housing.
Old Oct 21, 2009 | 03:42 AM
fc3si's Avatar
also tested the resistor box and it's good.
does the crank sensor have to spin to get injector pulse?
Old Oct 21, 2009 | 03:12 PM
fc3si's Avatar
it's a mystery.
Old Oct 21, 2009 | 03:19 PM
Digi7ech's Avatar
I break Diff mounts
^yes, you need to spin the cas to make the injectors fire.
Check the CAS plug. Mine got loose one time and wouldn't fire.
Old Oct 21, 2009 | 03:25 PM
fc3si's Avatar
so if i spin the CAS with the key set to "ON" i should get a pulse from the injector clip?
i'm pretty sure my CAS is good, i tested the resistance as per the service manual and it's within spec.
Old Oct 21, 2009 | 07:03 PM
Digi7ech's Avatar
I break Diff mounts
I've done it before.
I pulled the CAS out(only do if you know how to put back in correctly) Then left it plugged in and key on. I spun it and heard all the injectors going off.
You can check the injectors going off by sticking a multimeter in to the backside of the ECU plug.
You'd have to check the Service manual to determine which pins are the injectors. You also shoudl only test the primaries. The secondaries won't come on unless you're over 3800 rpm.
Old Oct 21, 2009 | 07:55 PM
Also make sure that you are checking the right injectors. The Primary injectors are very difficult to get at. The secondary injectors are quite visibile and like Digi7ech said will not fire untill over 3800rpm.
Old Oct 21, 2009 | 08:05 PM
fc3si's Avatar
i know, i have the upper intake manifold off.
Old Oct 21, 2009 | 08:16 PM
fc3si's Avatar
i'm going to get a new battery 'cause mine exploded last night sending me to the E.R lol
after i get the new batt i'll check the voltage at the clips and check if the injectors click etc
thanks for the help people
Old Oct 22, 2009 | 01:37 AM
fc3si's Avatar
picked up some free 450cc DSM injectors, gonna try those out.
what's the flow rate on the stock primarys? 460cc right?
Old Oct 22, 2009 | 05:10 AM
fc3si's Avatar
okay, update...
installed DSM injectors and finally got pulse!!!
the car almost started then just bogged out.
and there's a major fuel leak.
i'm gonna do some investigating and repairs.
updates coming eventually.
thanks for the support..
Old Oct 22, 2009 | 01:57 PM
irishpilot's Avatar
*** man, good luck...
SO youre injectors were bad? Or was it wiring?
--im having similar issue after my 13b swap....
Old Oct 22, 2009 | 03:10 PM
fc3si's Avatar
Yes, it was the injectors.
still won't start but that 'cause i have a bad fuel leak
Old Oct 22, 2009 | 03:44 PM
irishpilot's Avatar
do you know if the 88' has a resistor box for the injectors?? I dont believe I have one for my swap....
Old Oct 23, 2009 | 04:09 AM
fc3si's Avatar
fixed everything. car still won't start. i have a feeling it's a timing issue.
i have everything set PERFECTLY and it still won't start?!
any pointers?
Old Oct 23, 2009 | 05:33 AM
fc3si's Avatar
Get fuel, and when i pull the plugs they are wet.
gets spark, shocked myself a few times lol.
but it won't start!?
wtf?
Old Oct 24, 2009 | 10:20 AM
Aaron Cake's Avatar
Engine, Not Motor
Likely flooded. You can put a little oil into each chamber to build up compression. Or, you can cut through the BS and just push start it with another vehicle. That always works.
Aramir
Oct 18, 2015 02:39 AM
Devon Murray
Sep 26, 2015 08:15 AM
