Raise the Redline RPM?
Old Oct 18, 2009 | 08:16 PM
hachiidori's Avatar
this may be a very stupid question, but is something ive never known..
WHat raises the Redline of an engine?
say your cars redline starts at 8500, what mod or mods would you do to make it higher?
Is it simple replacing of parts with more durable ones??
Old Oct 18, 2009 | 09:05 PM
mar3's Avatar
Administrator
There's the artificial redline on the tach that is more about durability and wasting time spinning than it is about the engine's real redline. You raise that by dialing the **** up on an aftermarket tach, drawing a new redline on your stock tach or pulling the over-rev buzzer so you're not over-revving anymore.
The real redline, at its most basic component, is about airflow efficiencies of the engine's intake and exhaust tracts. Improve them and the engine spins faster to its new redline. When it dies, you just went past its new redline...how long you want the engine to last at that new redline is where component upgrades becomes necessary. It might turn out you haven't hit the real redline yet once you have those new components in...and so it goes....
Mario III
Old Oct 19, 2009 | 09:42 AM
Aaron Cake's Avatar
Engine, Not Motor
If you want to raise the redline of the engine, you need to start by rebuilding it. The rotating assembly needs to be balanced and depending on how high you want to go, you may require a two piece eccentric shaft with a center support bearing. The rotors should be lightened and you'll need to run the clearances a little looser on the seals.
Deep groove rotor bearings, hardened stationary gears, three window bearings and higher oil pressure.
You will need to replace the stock intake manifold because it's out of breath, probably going to something like an IDA setup with short runners.
You'll need a full standalone to control the engine.
Old Oct 19, 2009 | 02:09 PM
hachiidori's Avatar
i see...how exactly would the two piece eccentric shaft work?? isnt it just one long one that runs through both rotors?
also mar3, you said its also time wasting revving higher. is your opinion based off the fact that after a certain RPM, the power and torque drop? To correct that.....do they have turbos designed to work at higher RPM's??
Last edited by mar3; Oct 20, 2009 at 11:06 AM. Reason: killd quote since reply was back-to-back to post in question...
Old Oct 20, 2009 | 09:17 AM
Aaron Cake's Avatar
Engine, Not Motor
Two piece eccentric:
http://www.rotorsportsracing.com/per...ru2pcshaft.htm
Old Oct 20, 2009 | 11:07 AM
mar3's Avatar
Administrator
"high boasted turbo engines".... ...
Old Oct 20, 2009 | 12:15 PM
lastphaseofthis's Avatar
My job is to blow **** up
Originally Posted by Aaron Cake
..... The rotors should be lightened and you'll need to run the clearances a little looser on the seals.......
Reduces crankshaft flex therefore rotor clearance can be set to a minimum and seal clearances can be set tighter for increased horsepower
Looks like we have some opposite opinions... Ding Ding!!
Old Oct 21, 2009 | 01:10 PM
mar3's Avatar
Administrator
Aaron's advice is spot-on for reliability at high rpm's...not everyone will run the two piece eccentric for whatever reasons they have. If running the 2 piece eccentric, na or in a "boasted" engine, then you can tighten the tolerances...at your own risk.
Old Oct 22, 2009 | 09:17 AM
Aaron Cake's Avatar
Engine, Not Motor
Yep, what he said.
dona1326cosprings7
Oct 29, 2015 06:47 AM
eplusz
15
Oct 7, 2015 04:04 PM
baix2
Power FC Forum
Sep 28, 2015 09:40 AM
