Question about A/R on turbine housing ?
Old Oct 14, 2009 | 01:54 PM
Romanator's Avatar
I blew my turbo a few months ago and I'm shopping for a new one. I'm running an S4 Half-bridgeport motor with all supporting mods (cooling, injectors, etc.) in my FC. I used to have a T04R with a 0.70 A/R on the compressor and a 1.00 A/R on the turbine side. Now, I met a guy that's selling a T04S with a 0.70A/R compressor side and an 0.84 A/R on the turbine side.
When I was looking for a turbo in the first place, I was told that for a bridgeport motor you absolutely need a large A/R for the turbine side. I was told a 1.00 A/R would be perfect for bridgeport and an 0.84 would be good for a stock port motor.
Has anyone here experimented with an 0.84 A/R on a bridgeport or can someone explain to me what would be the difference ?
Old Oct 14, 2009 | 02:06 PM
Turblown's Avatar
Turn up the boost
Depending on the compressor with a half bridge I wouldn't run below a 1.15. To function properly they need very low exhaust back pressure. I would also be running a Q trim turbine with the To4R on your setup.
The more power and rpms you plan on the bigger the turbine and a/r should be.
Old Oct 14, 2009 | 02:18 PM
Romanator's Avatar
I plan on 450 whp and my old T04R had a P-trim. So if I understand correctly the larger the A/R on the turbine housing will be giving more power, right ?
Old Oct 14, 2009 | 02:31 PM
hondahater's Avatar
spending too much money..
I've got a .96 on my t70 half bridge setup and do admit that I've heard from some people that it's a bit small so I may go to 1.15 however I tell you that thing spools very quickly
Old Oct 22, 2009 | 03:00 AM
speedyrx's Avatar
definatly dont go smaller than 1.00 and stick with your t04r
Old Oct 22, 2009 | 04:50 PM
ronbros3's Avatar
my understand,, big turbine A/R makes HP,,, small A/R makes torque.
some place you have to chose a happy medium, for what you gonna use the car for!
Old Oct 23, 2009 | 07:10 AM
hondahater's Avatar
I've got a question. What causes higher increases in exhaust back pressure? Smaller a/r sizing or smaller turbine wheels? Also with the increased back pressure from a smaller turbine housing what are the major side effects of this? Very hot egts? I really need to get an hks or greddy log manifold instead of my ebay knockoff. I'm sure it won't beable to hold up to the heat.
Old Oct 16, 2019 | 09:04 AM
Viper GTSR's Avatar
Performance Veteran...
Old Oct 16, 2019 | 09:09 AM
Viper GTSR's Avatar
Delete
Old Oct 23, 2019 | 02:49 PM
Grum68's Avatar
Newbie
A/R is just a calculation between Ratio and Area. You can only compare A/R in same turbine family, and still only 8 out 10 times you will find the calculation to be linary with size. It is useless as measurement across different turbos, and can be misleading within same family.
Area ((cm2) is much more relevant. Saddly not all suppliers list the figures (ratio and area) behind the A/R calculation.
Example of confusion within same turbo family:
Area of 13cm2 and A/R 0.96
Area of 14.7cm2 on A/R 0.7
Same turbine wheel
Which of the two above turbine housing do you think is the largest turbine housing .... the high thin or the lower fat one?
The 14.7cm2 is largest in overall volute volume
Old Dec 21, 2019 | 03:56 PM
Henry Erazo's Avatar
Is your motor oversized studded or still retaining the stock tension bolts? What’s your internal work if you don’t mind me asking?
Old Dec 21, 2019 | 04:59 PM
BLUE TII's Avatar
Rotary Motoring
This Borq Warner turbine section flow chart shows the relationship between exhaust wheel size and exhaust housing A/R well in regards to overall flow.
Attached Thumbnails Question about A/R on turbine housing ?-turbinemap.jpg
Old Dec 25, 2019 | 08:50 AM
TeamRX8's Avatar
10000 RPM Lane
Anyone know what the deal is on the 70mm range inconsistency. Goes 0.83, 0.92, then blank, 0.80 (???), 1.22. Seems like a typo or general error, but it’s been that way for at least 5 years or so. Hard to believe they wouldn’t fix it if it was.
BC-FD3S
Sep 25, 2008 09:10 PM
spike2085
Oct 27, 2006 03:18 PM
mazda1000
May 15, 2005 10:19 PM
Suds7
Mar 16, 2003 09:28 PM
fast13b
Mar 29, 2002 10:05 AM
