twins or single
Old Oct 8, 2009 | 03:31 AM
krayton's Avatar
twins or single
just looking for some opinions. i got a fd and it has a single turbo setup. but it looks like total crap. small *** unknown turbo, shitty manifold and wierd *** wastegate.
now should i get stock parts and try to go back to something close to stock.
or should i keep running with a single turbo setup. ie standalone and fixing all the mess.
seems like i should just keep running with the single setup. next up would be a haltech. or locate stock twins and the rats nest to go back to stock.
Old Oct 12, 2009 | 01:03 PM
bigXSpete's Avatar
i think it depends on what kind of quality the turbo, manifold and wastegate are. if they are cheap china parts then trad someone for the stock twins or just swap out the turbo for something more fitting and go from there with your build. i guess it also depends on what you want to do in the long run with your car. gl with the build.
Old Oct 12, 2009 | 01:16 PM
breez33's Avatar
Depends on what you want to do. As far as i know, twin would be better for autocross and single for drag. I want do a twin setup with a small and medium turbo. The small would boost up to 8 PSI then the medium would take over and boost to 22 PSI.
Old Oct 13, 2009 | 12:56 AM
vipcivic's Avatar
post up some pics of your single turbo to see how it looks
Old Oct 13, 2009 | 11:36 AM
Matt Cramer's Avatar
I agree with Breeze, a lot of it depends on the intended application. Also note that a lot of standalone systems can have difficulty handling sequential twin turbo setups the same way the stock ECU works.
HalifaxFD
Canadian Forum
126
May 9, 2016 07:06 PM
sinistersam
Sep 13, 2015 07:17 PM
