Haltech Anyone using the Platinum Sport 1000
Old Sep 30, 2009 | 10:50 PM
RotaSpinna69's Avatar
I have decided on going with Haltech for my tuning and data needs. Doing some searching I see that most Haltech users have the E6X or E8. Anyone using the Platinum Sport 1000 yet?
I can get a GREAT deal if I buy the EMS, Wideband, and Plug-n-Play harness all at once.
Would just like to get some opinions before I take the plunge!
Thanks,
Andrew
Old Oct 1, 2009 | 12:06 AM
rx72c's Avatar
Top Answer: 1
Yes get the platinum sport 1000. ECU IS FUCKEN GREAT.
I have now installed and tuned a few of them and they are great ecus.
What ignition system do you have or plan to run?
The software on the platinum ***** all over halwin. their is no comparison.
Old Oct 1, 2009 | 07:21 AM
I'm running stock ignition/fuel and bolt-ons right now. But in the future, I will most likely be running LS1 coils.
Old Oct 1, 2009 | 08:53 AM
R-R-Rx7's Avatar
Rotor or no motor
how about the sport 2000? any thoughts rx72c?
Old Oct 1, 2009 | 09:02 AM
Claudio RX-7's Avatar
EFI Tech Wannabe
The PS2K and PS1K are identical in every way, the difference is of course that the 2K has more inputs and outputs than the 1K.
Here's a quick comparo:
PS1K --- PS2K
AVIs 4 --- 7
DPOs 6 --- 6
DPIs 3 --- 3
DSIs 1 --- 1
Also, on a PS2K, if you install it on a 13B for example you will have 2 injector outputs that can be reconfigured as DPO's, and either 2 or 3 ignition outputs that can also be set as DPOs, depending on your ignition system, so on a PS2K you could have as many as 11 DPOs.
On a PS1K, if you use the stock 2nd Gen coils, or wasted spark, you could have 1 output left, making that a total of 7 DPOs.
DPOs, for those of you who are used to the old terminology, are the same as the PWM outputs, as they were called before.
Old Oct 1, 2009 | 10:37 AM
fritts's Avatar
Mad Man
Currently running a Sport 1000 with about every AVI used (WBO2, Oil Press, Oil Temp, 2XEGT's). Love the software but am still waiting on laptop logging. Current logging is through the ecu only and take several minutes to download and view a log (pain in the rear)...
There are Rotary specific ecu's that will be coming out soon as well. My guess is they will be around the price of the new sprint 500 ecu's and have similar options for outputs (less than the Sport 1000).
Old Oct 1, 2009 | 10:50 AM
R-R-Rx7's Avatar
Rotor or no motor
could you run the OMP with the haltech 1000 or 2000?
Old Oct 1, 2009 | 02:15 PM
C. Ludwig's Avatar
www.lms-efi.com
Yes.
Old Oct 1, 2009 | 04:34 PM
EFI Tech Wannabe
Be patient Ryan, 1.06 is coming
Old Oct 1, 2009 | 04:39 PM
rx72c's Avatar
Top Answer: 1
I was actually hoping haltech would get the knock sensor/software out for the haltech first.
Once they have this. Ill put it all in my rx7 and set it all up. Want to see what the haltech 2 step is like.
Old Oct 1, 2009 | 06:42 PM
streetRx7's Avatar
Should be installin mines pretty soon on my 3rd gen.... Stock ignition for now .. but upgrade everything else..
Old Oct 1, 2009 | 07:48 PM
R-R-Rx7's Avatar
Rotor or no motor
im seriously thinking to change the pfc for a better stand alone and some better coils as the twin power is not as strong
Old Oct 1, 2009 | 11:03 PM
rx72c's Avatar
Top Answer: 1
We do an ignition upgrade for the Power FC.
Its a full CDI setup with 4 coils etc, runs wasted spark.
Pm me if your interested.
Old Oct 2, 2009 | 03:48 AM
C. Ludwig's Avatar
www.lms-efi.com
The PFC will run four of these. Gives great results.
http://www.034motorsport.com/product...roducts_id=277
Old Oct 2, 2009 | 10:22 AM
R-R-Rx7's Avatar
Rotor or no motor
so you reckon i should stay with the pfc i get these coils?
Old Oct 2, 2009 | 10:45 AM
C. Ludwig's Avatar
www.lms-efi.com
Depends on if the PFC is meeting your needs for fuel, driveability, and aux function control. If you need to step up to something more powerful in those regards I'd love to sell you a Haltech. But if you're looking for improved spark it doesn't get much better than the Mercury coils. We've had very good results with them.
Old Oct 2, 2009 | 08:16 PM
R-R-Rx7's Avatar
Rotor or no motor
As you know the pfc runs on 16bit. does not have o2 sensor feedback among with other disabilities that can help you do a fine tuning ...
I dont want to change my harness either so thats what makes me lean towards the haltech
Note that my fd is a 2002 with the 16bit harness
Old Oct 2, 2009 | 10:28 PM
rx72c's Avatar
Top Answer: 1
I have yet to see a FD with a good condition harness already in it.
We usually redo the wiring harness from scratch for the FD or buy a New one from mazda. The heat absolutely kills them.
Old Oct 2, 2009 | 10:36 PM
R-R-Rx7's Avatar
Rotor or no motor
i bought my car brand new...its possibly the only fd with a good wiring harness then :P
Old Oct 3, 2009 | 04:43 PM
rx72c's Avatar
Top Answer: 1
Just noticed yours is a 2002 model. That probably explains it
Old Sep 16, 2018 | 07:25 PM
rx7singhs's Avatar
nope!
Logan Reinisch
44
Sep 17, 2018 12:20 PM
wstrohm
24
Oct 5, 2015 11:35 AM
musker
Oct 1, 2015 05:58 PM
