Sponsored by: CARiD
Temporary fix for oiil smoke?
Old Sep 30, 2009 | 11:18 AM
RX744CSP's Avatar
I have a 1990 13B which, if run hard then let off the throttle and then accelerate again will blow a big puff of blue smoke. This indicates bad side oil seals on the rotors, or so I understand. I have been told there's a temporary fix for this; if so can someone enlighten me?
If it helps, the car that the engine came out of was sitting for an unknown time, at least a couple of years and maybe as long as 4 or 5 years. I dumped ATF in the motor and spun it over before cranking. I also am running 60:1 premix (cheap stuff) until I am assured there's no MOP issues. The engine now has maybe 3 hours of run time on it since its reawakening. It fired up very quickly, none of the 'drag it behind something else' starting issues. I expected smoke at the outset but it hasn't gone away.
Old Sep 30, 2009 | 12:41 PM
NoviceRotaryTech.'s Avatar
Home-brew Rotary
Keep running it for a while.
I put ATF in one of my motors, an it smoked for a couple days.
Ill never put that **** in a rotary again.
If it keeps smoking, something prolly gone bad.
Old Oct 1, 2009 | 01:33 PM
Vierte's Avatar
yea its called a rebuild... which is only temporary cause you know its going to blow up again. :0
Old Oct 1, 2009 | 02:02 PM
RTRx7's Avatar
Rammer Jammer
If you are worried about seals going the "ATF trick" was the wrong thing to put in there...
Old Oct 16, 2009 | 05:43 AM
slpin's Avatar
7th Heaven
you will be surprised at how much oil/atf can be collected in the exhaust
go drive it around, get it hot, report agian in a few days
if its still there... then worry....
why 60:1?
doesnt mazda run 200-250:1 and 100:1 is the generally agreed amount?
Old Oct 17, 2009 | 07:46 PM
mustanghammer's Avatar
60:1 is pretty extreme. I would think that some or all of the smoke is from too much pre-mix. We run 100:1 with no MOP. Add more gas!
If the engine smokes on lift throttle then it is likely that an oil control ring has failed. The only real repair is an over-haul - the seals are a part of the gasket set. I was able to stop the smoke temporarily by putting in a qt of Hyperlube No Smoke.
Old Dec 26, 2011 | 11:38 AM
NCross's Avatar
I have a rotary addiction
mods please delete this post... wasn't paying attention of the date...
ls1swap
Jun 3, 2024 03:25 PM
musker
Oct 1, 2015 05:58 PM
frosty1993
Sep 30, 2015 01:27 PM
dexter snoek
Sep 29, 2015 09:18 AM
