fd navigation
Old Sep 29, 2009 | 08:30 AM
fountain333's Avatar
fd navigation
I am putting a pioneer avic d3 navi unit in the car and was wondering if anyone knew where i could pick up a speedo pulse and also where to pick up the reverse signal at?? There should be a speedo imput up by the cluster and i am guessing that there is a reverse light wire somewhere around the transmissoin?? Thinking that someone has done this here before??
Thank you for all your help guys!
Old Sep 29, 2009 | 10:52 AM
F1blueRx7's Avatar
Couldn't stay away
I didn't hook up the speedo wire. I'm relying on the GPS alone to handle the speed calculation. However you can pick up the speedo signal at Connector X-14.
"Connector X-14...located under the dash on the passenger footwell area, it's the white connector up behind the RX-7's blower motor near where the emissions harness passes thru the firewall.
...orange (manual cars) or blue (automatic cars)...this wire went to the ground side of the RX-7's VSS sending unit, which was located in the driver's side of the RX-7 transmission's tailhousing. If you are tracing the dash harness half of this X-14 connector, these wires change to yellow w/ white stripe.
.black wire w/ red stripe (manual cars) or yellow w/ blue stripe (automatic cars)... comes from 15a fuse in underdash fusebox. This is the power source for the back-up lites. If you are tracing the dash harness half of this connector, these wires change to black w/ yellow stripe."
(Credit to http://www.grannysspeedshop.com/ for that information)
Old Sep 29, 2009 | 01:22 PM
Supernaut's Avatar
Why would you want to do this? I like that the GPS does the speedo calculations.
Old Sep 29, 2009 | 05:58 PM
F1blueRx7's Avatar
Couldn't stay away
The Avic manual states that navigation will be more accurate if you use both sources.
Old Sep 30, 2009 | 08:58 AM
Wow thanks so much for the information!! Should be up and running in no time!
zyph3r
Canadian Forum
Sep 16, 2018 07:14 PM
TrboMike
NE RX-7 Forum
Sep 28, 2015 09:40 PM
Coolant_Leak
Aug 30, 2015 11:18 AM
