tach doesn't work!
Old Sep 26, 2009 | 06:48 PM
kevyn_rx7's Avatar
I'm charming
tach doesn't work!
i've checked a few other threads and haven't found anything yet. My car was down for about 2 or 3 months and when we went to start it up the tach wasn't reading at all. The voltage, oil pressure and fuel level are all working still though.
Any ideas?
Old Sep 27, 2009 | 10:47 AM
w.sen's Avatar
In a Bucket
do u know is any abody took out the shift buzzer?.. Some body did that on mine it wouldn't work cuz the buzzer has 4 solder point in the ciruit board.. Witch caused it not to work.. I solder the holes closed on the board and it works fine now
Old Sep 27, 2009 | 11:42 AM
Ryan123's Avatar
The Slowskys
The tach runs off the trailing coil. Check the connections, try to spray it with cleaner and make sure its securaly grounded (it grounds throught the bolts). The trailing coil is right next to the drivers side shock tower.
Old Sep 27, 2009 | 12:20 PM
kevyn_rx7's Avatar
I'm charming
cool i'll check on both of these things. thanks guys.
Old Sep 27, 2009 | 12:53 PM
w.sen's Avatar
In a Bucket
Ya a lil sand paper on the contacts won't hurt either.. Where it screws in on the circuit board
streetlegal?
Mar 17, 2022 02:46 PM
Thor 18
Interior / Exterior / Audio
Sep 13, 2015 08:39 PM
thecody59
40
Aug 23, 2015 06:41 PM
