The most miles on original 13b
Old Sep 7, 2009 | 12:36 PM
bbutchart@carolina.rr.com's Avatar
I have an 85 gsl-se 13b engine with 199,071 original miles on it.
Curious how many others out there have a lot of miles on an original 13b engine. Post your model and milage
Old Sep 7, 2009 | 12:39 PM
millennm's Avatar
I'm up to a whopping 44K.
Old Sep 7, 2009 | 03:37 PM
j9fd3s's Avatar
Community Builder
one of my high school friends has a gsl-se with 256,000 on the engine, its fine!
Old Sep 8, 2009 | 05:18 PM
takhay's Avatar
IIRC, I'm at just over 276,000 right now. Too lazy to check my odometer...
Old Sep 8, 2009 | 07:56 PM
takhay's Avatar
oops, my bad. only at 261,926. not quite sure where that other number came from...
Old Sep 8, 2009 | 08:11 PM
TitleChamp's Avatar
im at 107, 789 mi
Old Sep 8, 2009 | 08:12 PM
TitleChamp's Avatar
im at 107, 789 on my 85 gslse
Old Sep 8, 2009 | 08:58 PM
HadaGSL-SE's Avatar
1st gens only
I had one with 283,000. Smoked a little. Broke up around 4k RPM but not motor related. Gave it to my buddy and it should still be running.
Old Sep 8, 2009 | 09:05 PM
85rx-7gsl-se's Avatar
I only have 1.3liters
Mine went to the 28Xk range...Still ran when pulled but needed the oil trick on occasion. Would still chirp through 4 gear tho
Old Sep 9, 2009 | 12:08 AM
thunkrd's Avatar
i'm a poser
183 thousand on mine
Old Sep 9, 2009 | 12:16 AM
SlideRiceFC's Avatar
My 88 FC was at about 216K when I sold it several months back. Other than an oil leak it still ran great.
Old Sep 9, 2009 | 11:16 AM
Jeff20B's Avatar
Lapping = Fapping
GSL-SEs run too well for too long. The apex seals wear down to like 5mm height but never really gain much side slop until it's too late. The apex seal rolls out and breaks like the original FC 3 piece 2mm seals. High mileage is cool, but nothing to be proud of. Do a quickie rebuild!
Old Sep 9, 2009 | 12:21 PM
80's old school's Avatar
common sense prevails....
What is the oil trick? My 12a uses way more oil than it should and if you sit at idle, smokes some when you take off.
It is a 30 year old engine that has never been opened.
Old Sep 9, 2009 | 03:24 PM
Good to know with proper care they can last well past 200K miles.
I want to build a faster engine eventually which would take more $.
Is it really worth it for home mechanic to do a quick rebuild? Ive never rebuilt rotors and housing, just cleaned / replaced upper /lower manifolds.
Old Sep 9, 2009 | 10:47 PM
Oil in the spark plug holes to compensate for poor compression
Old Sep 9, 2009 | 11:16 PM
rotarycrazy's Avatar
Leave my avatar alone!!!
myne has 167k My buddy has a 85 SE and it has 408K the motor still ran but had wery little compresion.
Old Sep 10, 2009 | 06:50 AM
What good does that do?? Improve compression for what.......a minute?
Old Sep 13, 2009 | 02:17 AM
Keeble's Avatar
so you can start it i think
Old Sep 24, 2009 | 09:09 PM
silver80sa22c's Avatar
not a 13b but just hit 90k on my 85 gs
Old Sep 24, 2009 | 09:38 PM
chris rx7 gsl-se's Avatar
gsl-se only 13b
130k on my 85 gsl-se runz great but im having wiering problem's from a dam after market alarm that im am gaining on slowly
Old Sep 25, 2009 | 12:18 PM
jshiz's Avatar
Actin Like I'm Drunk
Nearing 140K
Old Jun 15, 2011 | 07:02 PM
Ronald_Ferguson's Avatar
Original owner
1988 GXL
Original engine, never rebuilt, now in excess of 268,000 miles
...... and it is starting to eat lots of water.
Old Jun 15, 2011 | 08:15 PM
Jibaro 12A's Avatar
searching...
254K in my 13B powered 81 GS
Old Jun 19, 2011 | 01:45 PM
rotorsport72's Avatar
well i had a 1983 gsl with a 12a that give me 329.??? miles smoke on high revs only and i still rebuilt it steetpoted and ran it for like 3 years then blew it on a high rev carb linkage got stuck then rebuilt it again but just use the side plates now its a 13b same streetport on my 71 rx3
ncds_fc
Aug 15, 2015 10:06 AM
