Rotary Drag Racing The place to post your racing stories and info
1st gen FRONT DRAG WHEEL SIZING needed. ~~
Old Sep 3, 2009 | 05:40 PM
Viking War Hammer's Avatar
*** Bless The USA
Red face 1st gen FRONT DRAG WHEEL SIZING needed. ~~
I've got the GSL SE front's.
1st- What's the bolt pattern? I've heard they're 4X4.5 and have also heard they're 4X4-3/4. Which is correct?
2nd- What backspace are you guys running?
3rd- Are 26" tall tires too tall? My rear tires are 28" tall, so I'd like things to match up nicely.
Old Sep 3, 2009 | 05:46 PM
sk8world's Avatar
Chasing numbers
Tirerack has a section that shows you how to measure and you will know 100% what you got. On tires I bet 26's are going to look huge unless you can get that front to sit way down??? IDK..... I would go for the 25's... You can always send them back.
Old Sep 3, 2009 | 05:57 PM
cptpain's Avatar
Torqueless Wonder
GSL-SE bolt pattern is 4x114.3, which im sure is 4x4.5
Old Sep 3, 2009 | 06:07 PM
*** Bless The USA
Yeah, I know how to measure but I'm stuck at work and I'm being impatient
My old FD had 26's up front so I didn't think there would be that much difference between the two.
Old Sep 3, 2009 | 06:08 PM
NoPis10's Avatar
Committee Member #2
That is correct... 4x4.5 with a 4 1/2 inch backspacing.
Alot of guys run the drag lites that fit on Mustangs...
L8R
Old Sep 3, 2009 | 06:10 PM
*** Bless The USA
L8R
Thanks, I'm waiting to hear back from Holeshot. I'm trying to see if they can drill out some Holestar's for 4 lug. I'd like something that matches my rear Holestar's.
Old Sep 3, 2009 | 08:18 PM
Gohan3rdrift's Avatar
Movie Star
ppsshhfffh...show cars.
Old Sep 4, 2009 | 08:49 AM
n0ferz's Avatar
Hey let me know if they can do this for you, I like the style and would like to see if they can supply them in 4 x (4.5) lug pattern.
Old Sep 4, 2009 | 03:01 PM
*** Bless The USA
Can someone confirm that the correct backspace for 15x4 wheels is 4 1/2 inch ?
Old Sep 4, 2009 | 05:11 PM
*** Bless The USA
L8R
Wait, how am I going to have a 4 1/2" backspace when the front wheels are only 4" wide?
Old Sep 6, 2009 | 10:06 AM
*** Bless The USA
Anyone?
Old Sep 7, 2009 | 08:02 PM
1BADSP's Avatar
the front wheels only come in one offset,it is a zero offset they are only 3.5 or 4 in. wide. my draglites are exactly that 4 on 4.5 wich is gsl-se.
Old Sep 10, 2009 | 01:43 PM
*** Bless The USA
Well, holeshot says the holestars can't be drilled for 4 lug. So, it looks like my only option is the Holeshot Mod Stars.
Do you guys think the Mod Stars will match my Hole Stars?
My car, and my rear Hole Stars.
And, the Mod Stars, still a 5 Star wheel but it's slightly different. I would have the centers anodized to match the rears.
Old Sep 10, 2009 | 02:04 PM
*** Bless The USA
and it looks like they offer backspacing in 1-7/8" or 2-7/8". Hmm..
Old Sep 10, 2009 | 02:10 PM
freddyrx3's Avatar
Do what i did with my rx3...Buy an Aerospace brake kit as 5x4.5 BP to bolt up to your spindle style, then call holeshot and order them. Very Simple. You are going to end up upgrading your front brakes anyway, with that kind of power! It will look very nice.
Old Sep 10, 2009 | 09:30 PM
ultimatejay's Avatar
^+1, that's what I did. Also the Aerospace brakes bring the offset inwards a little so wheels like Welds fit better. Go with the largest offset they offer.
Old Sep 24, 2009 | 06:07 PM
mannyvidal's Avatar
come get some.....
what i did was drilled my lower control arms one inch and brought them in i had to cut my tierods also 1/2 inch on both sides and got tony at www.awrracing.com to modify me his second gen camber caster plates to fit my first gen and that was no biggie cause all we did was shave the strut neck so it could fit inside the plates , and i used miata coilover's for the front wich he also suplied direct fit over the tube and welded them pupies on , it gives me all the clearence i need cause up front i use toyo 25x4x15
Old Oct 1, 2009 | 10:04 AM
*** Bless The USA
those that are using theracingstore aerospace kit, did it keep the same backspace or what?
I'm thinking I might just go ahead and order it.... don't want to, but whatever
Old Oct 13, 2009 | 04:34 AM
sen2two's Avatar
Rx2 > FD
you can just bolt on the standard weld wheel skinnies up front with no problem. if you upgraded the calipers at all, just use specers or an adapter. most racing sanctioning bodies require the use of longer wheels studs anyways. so using a spacer to clear is no big deal if needed.
Old Oct 22, 2009 | 02:38 AM
speedyrx's Avatar
24inch tires look the best
FD7KiD
15
Feb 26, 2021 10:12 PM
ChrisRX8PR
Aug 21, 2015 01:56 PM
Frisky Arab
13
Aug 18, 2015 05:30 PM
KAL797
Test Area 51
Aug 11, 2015 03:47 PM
