Megasquirt NO power to injecters
Old Sep 2, 2009 | 04:48 PM
pedro's Avatar
importdynamix2004
TX NO power to injecters
hi there guy i install one off my MQS in every thing is wire in but there no power the my injecters.there not clicking help please.the msq have good power and ground
Old Sep 2, 2009 | 07:22 PM
13bdarren's Avatar
you need to supply the power to the injector the ms ecu ground them to make them pulse.
Old Sep 3, 2009 | 11:33 AM
pedro's Avatar
importdynamix2004
TX Msq
thank you bro.there the blue wire that runing to the lower injecters,and the green wire to the upper one. can i run a power wire powering up all the injecters ? on the pig tail for my injecters the a red and black wire.im useing the red for signal is that ok or change it around
Old Sep 3, 2009 | 04:15 PM
pedro's Avatar
importdynamix2004
Old Sep 3, 2009 | 07:24 PM
13bdarren's Avatar
I don't think it matter as long as there is a fused 12v source. I made my own harness so I don't remember wire colours. Just check with voltmeter for power at all injector and you should be good.
Old Sep 3, 2009 | 08:18 PM
pedro's Avatar
importdynamix2004
cool thank bro i have one more ? there power to my injecters and power to my msq.but when i turn her over there no spark.on my cas im only useing the red and white wire is that ok ?
Old Sep 4, 2009 | 04:34 PM
13bdarren's Avatar
I think those are the right one if you are using the shaved tooth method not the duel vr sensor.
Old Sep 4, 2009 | 10:22 PM
pedro's Avatar
importdynamix2004
on the cas.we remove 2 tooth out of her.i was looking at my laptop when i turn it over the no spark.i pull the cas out and turn it.by hand and there spark.the only one i see move is the map move on my laptop.that it.
Old Sep 5, 2009 | 12:45 PM
13bdarren's Avatar
Sounds like a grounding problem. Make sure your wires are shielded and the grounds are like the faq recomends. Also try reversing the wires on the cas to see if they didn't get mixeds up.
Old Sep 8, 2009 | 09:43 PM
pedro's Avatar
importdynamix2004
ok thank's bro.i have not try it yet.i was rebuilding two engine today 2 TII S4 and S5 I had them just siting down.so there ready to go if someone is looking for a TII engine.ill try the wire tommrow thank again
Th0m4s
Feb 26, 2019 02:04 AM
rotor_veux
Sep 3, 2015 07:10 PM
rx7shirley
Sep 2, 2015 02:11 PM
