West RX-7 Forum Serving California, Nevada, Arizona, Hawaii
Need answer on buying this car
Old Aug 28, 2009 | 10:50 AM
OkamiAmaterasu's Avatar
Life As RE Know It!!
ok i found a 88 RX7 body is great, needs paint though, interior is good just missing the center things and thats about it, the engine is all there even power steering, but the car has yellow stuff all over it. i am thinking its from water so that puts me to think that it has overheating problems... the guy says that the water pump was busted and that they fix it but i dont trust and not sure.
so my question is should i buy this car? i will fix it but will it cost alot to fix the water pump and stuff?
Old Aug 28, 2009 | 10:54 AM
FC_EDDIE's Avatar
Water pumps dont explode, they leak. if it's covered in orange-ish stuff, it most likely was a radiator hose (upper one most likely). Easiest way to find out if its worth getting...test drive it then before shutting it down, let it idle and see if it overheats.
Old Aug 28, 2009 | 12:30 PM
RotaryDreamz's Avatar
INCREASE THE PEACE
How much is he looking for it?
Old Aug 28, 2009 | 01:15 PM
FC_EDDIE's Avatar
also what model? GXL, TII, SE??? Miles?
Old Aug 28, 2009 | 02:21 PM
CaliSwag707's Avatar
Where am I....
here ya go bruh this is some faqs from icemark
https://www.rx7club.com/2nd-generation-specific-1986-1992-17/frequently-asked-questions-2nd-generation-rx-7-faq-fc-494667/
here is one of the fact that might help you bruh also from icemark
What should I look for when buying a 2nd Gen RX-7?
Non Turbo: http://www.aaroncake.net/RX-7/buy1.htm
Turbo: http://www.aaroncake.net/RX-7/buy2.htm
General: http://fc3spro.com/TECH/h2b.html
good luck bruh
FDNewbie
161
Sep 6, 2015 11:10 AM
plentymoon
NW RX-7 Forum
Sep 5, 2015 08:55 AM
ChrisRX8PR
Aug 21, 2015 01:56 PM
cam_7779
Aug 18, 2015 07:48 AM
blkops
Aug 12, 2015 01:30 PM
