HX35, 7blade (600bhp) comp, 12cm exhaust- any good for a 13BT?
Old Aug 24, 2009 | 07:12 PM
StavFC's Avatar
As title really, as I have an almost limitless supply of them, so would make sense to use them
Compressor is about GT35R size in capability, turbine flows really well despite it "only" being a 12cm T3 divided housing- used one on a 5litre V8 and didnt seem to even strangle that revving it to 6k and pushing around 500 horse, BUT is it too small for a street ported 13B?
Car currently has a T04E on it, as it came over from Japan, at least I was told its a T04E, fairly small compressor whatever it is, and my manifold has cracked so I need to remove it anyhow, and while I was at it, if its not going to be worse than whats on it currently, id be tempted to swap to a T3 flange and run the HX35s, as like I said, I have a huge supply of the 7 blade '600bhp' ones here.
Anyone ran a 7 or 6 blade (not the lower power 8) 35 on a 13B and can give any experiences of it?
Thanks
Old Aug 24, 2009 | 08:58 PM
catch-22's Avatar
The T3 holsets are going to be way to small. I run a WH1E with 26cm housing and i get 15psi at 3200 ish with a streetport.
Old Aug 24, 2009 | 09:14 PM
rnz520's Avatar
No Pistons
26 cm is a big housing, you are moving a lot of air. What kind of power are you making?
Old Aug 24, 2009 | 09:57 PM
catch-22's Avatar
417
Old Aug 24, 2009 | 10:51 PM
ScorpionT's Avatar
Definitely too small for 600hp. The turbine side might be sufficient for 600hp, but the compressor definitely isnt up to par.
Old Aug 24, 2009 | 11:27 PM
WaachBack's Avatar
Finally Knows
To small for sure. If you have access to Holsets and want 600hp. Get an HX50, HX52, or HX55.
Old Aug 24, 2009 | 11:32 PM
Turbo II Rotor's Avatar
Who Shot the Sheriff?
He's describing the turbo, it's obviously "Piston HP". He just wants to replace his turbo and manifold and make a couple extra HP.
Old Aug 25, 2009 | 03:51 AM
StavFC's Avatar
As above, I dont want 600bhp, I just meant the compressor can do 600 as its not the more common 8 blade ones, 400-450@fly would be fine, think its only about 350 as it is!
So its honestly too small for even that? I mean we put one on a 5litre revving to 6k and it didnt strangle it like a lot of "bigger" turbos did previously.
Has anyone actually tried one on a 13B or?
82streetracer
Haltech Forum
11
Mar 11, 2019 05:34 PM
sen2two
AEM EMS
Oct 23, 2015 07:51 PM
ChrisRX8PR
Aug 21, 2015 01:56 PM
