Compression
Old Aug 22, 2009 | 12:53 AM
goose415's Avatar
Drift Happens
Compression
i just did a compression check on my FC. 90psi with the front and 98psi with the rear..... what are good compression readings?
Old Aug 22, 2009 | 02:14 AM
RotaryRocket88's Avatar
Top Down, Boost Up
100+ psi would be be "good" numbers. 90s are ok. The specs listed in the FSM are something like 85 psi minimum, but obviously higher is better. Also be sure the throttle is open and the tester hose isn't too long, as these factors can change the numbers slightly.
Old Aug 22, 2009 | 04:23 AM
Kerberos_8's Avatar
those are good it also depends on your year as s4 rx7s have lower compression rotors then s5. I believe 75 psi is like minimum and i have seen them run with like 60 psi. 90+ i would say is good and 100+ is like a rebuilt motor
Old Aug 23, 2009 | 11:36 PM
goose415's Avatar
Drift Happens
its an 87 GTU and it smokes alot but put those compression numbers up.
Old Aug 26, 2009 | 06:43 AM
Kerberos_8's Avatar
rotary engines dont smoke because of low compression like piston motors do. If it smokes alot its either because its leaking coolant and burning it or the oil control rings are worn out. If the oil control rings are worn out i wouldn't worry about it till it smokes so bad its unbearable. If its the coolant seals you would have to rebuild the motor
Old Aug 27, 2009 | 08:02 PM
goose415's Avatar
Drift Happens
oh... im a newbie to the rotary scene. thanx for the help.... but are those numbers good? it has 190000 miles on it.
Old Aug 27, 2009 | 09:14 PM
TwistedRotors's Avatar
Compression Tester Guy
Those numbers are good.
Old Aug 28, 2009 | 08:37 AM
schoolinz's Avatar
bump
turbodreamz22
28
Nov 10, 2023 11:08 AM
Andrew7dg
Aug 6, 2017 01:41 PM
93FD510
Oct 1, 2015 02:00 PM
