Sponsored by: CARiD
It's possible to get engine knock in rotaries as well right?
Old Jun 5, 2002 | 03:57 PM
AncientPC's Avatar
And when it does happen, what usually goes first, the rings or the seals? Or is it something else?
Old Jun 5, 2002 | 04:15 PM
CrackHeadMel's Avatar
Learned alot | Alot to go
knock?
detonation? if u mean detonation you very quickly loose your apex seals i belive
Old Jun 5, 2002 | 05:08 PM
user 84205's Avatar
OH YES knock is very available in these engines... If your going buy the stock sensor, then i wouldnt worry much about it, those are crap. Knock is detonation, it takes time as with any engine to kill it, but Apex seal and even the rotors can get a lot of damage...
Old Jun 5, 2002 | 05:30 PM
peejay's Avatar
Old [Sch|F]ool
For what it's worth detonation isn't usually possible in an N/A and when it does happen, overall cylinder pressure is low enough that it's usually non-fatal.
Turbos on the other hand... I've heard of inaudible knock causing engines to blow.
Old Jun 6, 2002 | 01:18 AM
RETed's Avatar
http://fc3s-pro.com/TECH/FAQ/deton.htm
-Ted
MoTeC
Sep 10, 2015 07:58 PM
