poor running na with turbo 2 swap
Old Aug 17, 2009 | 11:41 PM
sedalia_mo_87singleturbo's Avatar
Red face poor running na with turbo 2 swap
did the full turbo 2 swapp on my 87 na, except for the harness. my turbo 2 harness was hacked when i recieved the motor and trans. so i just modified the na harness. the engine runs great on th na ecu but when the turbo 2 ecu is pluged in it d=seems like it looses a rotor at 3k rpm. little help be nice. oh and i have read the faq many times but just havnt foungd my answer yet. any one have a write up on the harness modification needed to run a turbo 2 with a na harness? thanks a ton for any help. chris
Old Aug 18, 2009 | 12:13 PM
N3v's Avatar
N3v
sounds like it's taking a dump when you hit boost. it's probably adding an ungodly amount of fuel and bogging it out. what AFM and injectors are you running?
Old Aug 18, 2009 | 09:56 PM
RotaryRocket88's Avatar
Top Down, Boost Up
Click the link in my sig. There are many threads covering the details of properly swapping in a turbo engine.
bb6guy
Old School and Other Rotary
Oct 1, 2018 08:07 AM
JZW
20B Forum
Aug 18, 2015 08:56 PM
Machupicchu
Aug 17, 2015 08:27 PM
Professorpeanutrx7
Aug 15, 2015 01:38 PM
