Introduce yourself New members post about yourself here...
Mazda RX7 rhd Type R - Netherlands
Old Aug 11, 2009 | 05:12 AM
joffrey's Avatar
Hye Everyone,
I'm Joffrey from the Netherlands. I live there but I am originally from France. I am the owner of a grey 1993 RX7 type R. I imported it from England 3 weeks ago and I can finally drive it.
I was not supposed to buy the Mazda at the beginning and I was more into buying a toyota Supra twinturbo, but after the test drive of the mazda, I liked it so much that i changed my mind. The car runs perfectly except some little problem:
- Need to convert it back into kilometers
- Boost controller is giving me a pressure of 0.6bars max, probably a quick setting to make so it can go to 0.8 bars
- Little electric problem coming from one of the electric boxes under the bonnet. The electricity shuts down once in a while and when i shake a bit one of the boxes, it works again. It just happens when i screw up starting at a traffic light and the engine stops, it doesn't restart.
Concerning the equipments:
- Ohlins suspensions
- HKS Fcons
- Boost controller Greddy
- 3 discs clutch
- Stainless steel exhaust with no catalysator anymore
I'll put some pics later when it'll be a little cleaner.
Old Aug 13, 2009 | 07:48 AM
irishs2k's Avatar
great choices
Old Aug 13, 2009 | 08:07 AM
bridgeportfdjonny's Avatar
hiya mate, i am new aswell, but i had a similar proplem with mine with i cutting out and for some reason it only did it from a standstill. the problem i had with mine was 1 of my wire coming from the battery was shorting, thus cutting the electrics and blowing a fuse, i presume it could be the same thing, however i dont know why it would be fine after a quick rattle of what i presume is your fuse box.
my advice is check all of you fuses and wires coming from them, make sure there is no bare wires,
hope this help
jonny
Old Aug 13, 2009 | 10:12 AM
joffrey's Avatar
Thanks, I am supposed to check this week end what is the problem. I'll make a post about it. The engine bay needs a complete clean up so I'll take a look at it at the same time.
Old Aug 14, 2009 | 04:10 AM
wowpaw's Avatar
i never knew they had type r's for RX7s
Old Aug 14, 2009 | 06:03 AM
series 6
they made the efini rx7 from 1992-1995 as the type R, RB and RZ
series 7
minor updates on car like 16bit ecu, and was then sold as the mazda rx7 not mazda efini
series 8
later on the RS came along in 1999 along with the new RZ same as the rs just a little bit lighter the new series 8 rs and rz, then had better abs, better ecu and standard 17" wheels.
Old Aug 18, 2009 | 12:14 AM
jdm538's Avatar
i was in the same situation i wanted to get a mk4 supra turbo but it felt too big. the fd isn't as fast but it feels much better to drive.
Old Aug 18, 2009 | 12:18 AM
EviLPeNeviL's Avatar
Can't live without boost.
Welcome, hope you have a great time here!
D
Old Feb 26, 2010 | 09:25 AM
joffrey's Avatar
Been a while I haven't posted here. Battery problems solved, I needed to change the battery plugs cos the old one were all corroded. I found some stock wheels to change the ugly S14 wheels, and mounted a nice set of HKS filters with a japspeed rigid piping. I still have my HKS turbo timer, boost gauge and AFR gauge to install!!
elpartso_robb
Aug 29, 2015 08:45 AM
NJ-JDM
43
Aug 23, 2015 11:02 PM
