91 starts then dies
Old Aug 5, 2009 | 11:57 AM
davillerx7's Avatar
91 starts then dies
hi im new to the forum just trying to get some tips, i just swapped a 91 into my 87 it starts then dies n.e ideas
b.c. im out of at this point
Old Aug 9, 2009 | 05:01 PM
farberio's Avatar
NASA-MW ST4
More then likely you have a giant vacuum or air leak.
Can you keep the car running with you foot on the pedal?
Old Aug 10, 2009 | 02:21 PM
davillerx7's Avatar
ya... but i am using the old 87's ecu and wiring harness
could it be the bac?
Old Aug 10, 2009 | 03:18 PM
Rextasee's Avatar
808gxl
ummm if i were you id change the ECU!!!
Old Aug 10, 2009 | 05:02 PM
davillerx7's Avatar
i have the new ecu but still looking/waiting for the wiring harness's i also have the new mas air flow that is not yet installed...
and injector presure sensor
Old Aug 10, 2009 | 08:05 PM
farberio's Avatar
NASA-MW ST4
Use the 91 keg (motor) and all of the 87 accessories(front cover, omp, intake, etc, etc,...) and ECU. Putting in the 91 ECU and harness is more then just the motor, you will have to rewire most everything in the car.
There should be a write up on how to do this somewhere on the board.
rgordon1979
40
Mar 15, 2022 12:04 PM
sherff
Sep 12, 2015 12:22 PM
whinin
Sep 5, 2015 11:52 PM
rx7shirley
Sep 2, 2015 02:11 PM
