Sponsored by: CARiD
oil in turbo compressor housing?
Old Aug 2, 2009 | 05:37 PM
somchhir1's Avatar
Rotorite
I just installed the BNR stage 3 turbos, and everything was working great for about 2 days. then it started idling funny, so i thought it might be a vacuum leak somewhere so i pulled the y pipe off and noticed this greyish oil on the gasket. I got my flashlight out and shined it down into the compressor housing and noticed what looked to be a semi-dried up pool of oil. These turbos are used and i have only put about 15 miles on them. anyone know about the oil buildup and what may have caused it.
Ryan
Old Aug 12, 2009 | 07:52 PM
2J-Z's Avatar
Looks like bad oil seals = Bad turbo
But if it a ball bearing turbo and you dont have a oil restrictor on the turbo it will cause it to leak also. Put a Restrictor and you'll be fine
Old Aug 12, 2009 | 08:01 PM
Turblown's Avatar
Turn up the boost
If you still have the crankcase vents hooked up to the turbo inlet duct this is going to be normal. You should route them to a catch can instead.
Old Aug 12, 2009 | 08:09 PM
somchhir1's Avatar
Rotorite
well the turbo did blow...a kinked vacuum line may have caused them to overspool...so i'm in the process of having them rebuilt......hopefully no issues when i re-install...fingers crossed.
Old Aug 24, 2009 | 08:52 AM
full-cruise's Avatar
D.I.L.U.S.I.
Hey I'm woundering if the car smoked at idle, I think my turbo could be causing smoke when I idle and it will clear up rite after it see a few pounds or so
FD7KiD
15
Feb 26, 2021 10:12 PM
ChrisRX8PR
Aug 21, 2015 01:56 PM
FD7KiD
Aug 17, 2015 11:50 PM
