Need help about engines
Old Jul 27, 2009 | 02:03 AM
86_Rx7FC3S's Avatar
CO Need help about engines
ok will i recently just bought a 88" Rx7 N/A and it won't pass emission , but i am close to passing if it drops down a little more. When i took my car to a shop to fix what ever is wrong with it they found one of the o2 sensor was dead and when they replace it the reading for HC and CO got worse and when they did a compression test they told me it was putting out 60psi when its suppose to put out minimal of 80psi.
Please help me how can i fix this problem?
Old Jul 28, 2009 | 10:18 AM
Rx7_Nut13B's Avatar
Red Neck Tony Stark - C2
Did you take it to a Rotary shop, or a shop that knows how to work on a Rotay, because compression tests are not a simple thing as a piston engine.
a good trick to pass emissions is to add O2 to the exhaust during the test or, to run 20%-30% denatured alcohol in the fuel.
Old Jul 29, 2009 | 11:41 AM
86_Rx7FC3S's Avatar
No i haven't because i don't think there is a rotary shop or a shop that knows how to work on them in Colorado as i have ask around so right now i am in jam to get it fix as i dont have tools to test the rotary
Old Jul 30, 2009 | 02:41 PM
RotaryRocket88's Avatar
Top Down, Boost Up
If it truly has low compression, nothing short of a rebuild will fix it. You can try replacing your main cat, if it is old and in poor shape. Other than that, making sure your air pump is good and the split air pipe is connected properly would be useful.
Old Jul 30, 2009 | 03:20 PM
iani1.1's Avatar
DILLIGAF
which part of colorado are you in? i might be of help.
Old Jul 31, 2009 | 07:38 PM
86_Rx7FC3S's Avatar
well i am located in westminster but i can not drive it on the street as i don't have plates or temporary tags on it since i haven't found the time to go to the DMV to register the car under my name because of school
Old Jul 31, 2009 | 10:17 PM
Djonyx's Avatar
Originally Posted by rx7_nut13b
did you take it to a rotary shop, or a shop that knows how to work on a rotay, because compression tests are not a simple thing as a piston engine.
A good trick to pass emissions is to add o2 to the exhaust during the test or, to run 20%-30% denatured alcohol in the fuel.
+1
Old Aug 8, 2009 | 10:33 AM
86_Rx7FC3S's Avatar
will i talk to a local shop and they told me to run e85 at the emission and after that go and fill it up with regular octane.
does anyone know if your run e85 in a car that does not have the right stuff to run it will it damage the car?
Microtech
30
Apr 23, 2016 06:37 PM
Wicked93gs
Aug 23, 2015 10:14 AM
KAL797
Test Area 51
Aug 11, 2015 03:47 PM
