13b Oil fill tube
13b Oil fill tube
Does the oil fill tube thread into the intermediate iron, or is it pressed in? Also is it a good idea to use my S5 intermediate iron in my turbo build? My turbo iron is kinda gouged. The motor is being ported anyway. So I guess my real question is if I put a turbo intake port template on the na intermediate iron, will I be able to make it a "turbo iron"? (notice quotation marks.) I know that I would need to drill and tap the iron for the center bolt for the intake manifold.
Thanks.
Thanks.
I don't understand why you would do that. The tube can be removed by wiggling it up, with the help of a long lever. Then the other tube can be tapped in with a hammer.
KAL797
Test Area 51
Aug 11, 2015 03:47 PM
