GTU Steering rack leak???
Old Jun 3, 2002 | 11:09 AM
xjackhx's Avatar
I am buying an 88 GTU and the power steering rack leaks(about a quarter size every time parked). Is this a problem withh these car, and how much to get it fixed....THANKS!!!!
Old Jun 3, 2002 | 11:24 AM
Icemark's Avatar
that is normally not a common problem.
Don't know how much to get it fixed, because I don't know where the leak is exactly.
Old Jun 3, 2002 | 06:25 PM
Shady Haze's Avatar
Newbie
I have the same prob. Took it to the dealership to verify what exactly was causing the leak. They told me it was the entire rack & pinion, that the part is $1800 plus $600 labor I would find out for sure what the source for that leak is.
Old Jun 4, 2002 | 08:36 AM
Nigel2468's Avatar
I have an '86 GXL that had a similar problem when I bought it. I searched all over and found the problem to be from the PS pump itself, both from the reservoir and the shaft bearing. I bought a used PS pump from a local junk yard for $20 and put it in. No leaks at all.
Good Luck.
ZaqAtaq
Sep 5, 2015 08:57 PM
gabescanlon
Sep 5, 2015 12:04 AM
