need a turbo
Old Jul 11, 2009 | 12:49 AM
rotorykent's Avatar
need a turbo
i need a turbo for my 20b and i herd between 40r and 42r are really good witch should i go with?
Old Jul 11, 2009 | 01:53 AM
Chaotic_FC's Avatar
i think on a 20b theres no point on going with anything less than an 80mm turbo.. mabey a borg warner s480, or a 80mm GT42R.
What are you power goals with this engine? and at what PSI?
Old Jul 11, 2009 | 11:28 AM
rotorykent's Avatar
i want 500whp or more nothing less
Old Jul 11, 2009 | 02:33 PM
Japan2LA's Avatar
72mm turbo @ 10psi will make 530RWHP
Old Jul 11, 2009 | 02:44 PM
rotorykent's Avatar
ok does anyone know how much boost i can run before something happens or apex seal go on me ??
Old Jul 11, 2009 | 05:33 PM
Chaotic_FC's Avatar
that question depends on countless other factors.. but i wouldn't imagine before 20psi; which is plenty of power.
Old Jul 11, 2009 | 06:28 PM
patman's Avatar
Resident Know-it-All
I'd go with a 40R. I have a 4202R and I'm not even really into its efficiency at 575whp. A 40R should spool faster and still make plenty of power
Old Jul 12, 2009 | 12:16 AM
imtiaz's Avatar
what is the difference between the 4202r and the 42r
Old Jul 12, 2009 | 09:24 PM
Chaotic_FC's Avatar
dude you just asked that question in another thread.
If you are looking for a Big fat turbo that will still spool plenty fast, then go with a borg warner s475. They're 600 bucks.. you cant beat that really.
Old Jul 13, 2009 | 07:40 PM
ScorpionT's Avatar
I wouldnt go with a divided housing turbo, so the 40R and 42R are definitely not my picks. Dumping exhaust from 3 rotors into 2 halves of a turbo is a mess and you could lose power or have longer spool time.
I would go with something like a Precision 71-76mm, or like Chaotic said, S475. The Precision turbines are a little smaller than the BW units but they will spool quick and make nice power. The BW stuff is much less expensive though.
The GT4202 IS a GT42R. There are 2 variants of the 42R, they are the 4294 and 4202. The difference is the compressor wheel.
Old Jul 13, 2009 | 08:54 PM
imtiaz's Avatar
oh ok cool... the 4202 has a 102mm compressor what does 4294 have ? which would be better ?
Old Jul 13, 2009 | 08:58 PM
darinn's Avatar
i have a holset hx52 for sale its the one on the top...one on the bottom (NOT FOR SALE) is a holeset h2e
the holset hx53 specs: the comp wheel is 67mm, the exhaust wheel is 70mm, and the housing is a 16cm^2.
Old Jul 13, 2009 | 10:04 PM
rotorykent's Avatar
how much power and what pounds of boost?
Old Jul 13, 2009 | 11:30 PM
ScorpionT's Avatar
Measuring the exducer it has a 94mm compressor. I would recommend the 4202, its compressor is better for higher power because its more efficient at 15-25psi and higher airflow levels.
Old Jul 14, 2009 | 12:05 PM
RX-Heven's Avatar
I'll blow it up real good
I've got the turbo for you.
Brand New
T6 flanged GT4202R
Ball bearing/water-oil cooled.
pm me if interested.
Sorry for the spam
Old Jul 14, 2009 | 11:25 PM
rotorykent's Avatar
how much man??
FD7KiD
15
Feb 26, 2021 10:12 PM
Th0m4s
Feb 26, 2019 02:04 AM
C. Ludwig
Jan 30, 2019 06:31 AM
ChrisRX8PR
Aug 21, 2015 01:56 PM
