Have 800 to spend what should i do.
Old Jun 22, 2009 | 08:16 PM
benrl's Avatar
CA Have 800 to spend what should i do.
Ok my car is an rx7 88 turbo, it has straight pipes no precat or cat, it already has an intake, the interior and exterior are fairly clean, it runs well (when i dont flood it).
Here is my question I have 800 put aside that i would like to spend on the car for performance only mods, what mods would you recommend for me?
I was thinking a bov and boost controller?
Old Jun 23, 2009 | 11:55 AM
RotaryRocket88's Avatar
Top Down, Boost Up
Is your wastgate ported? The stock S4 wastegate is tiny, and an open exhaust and intake will make you boost creep to 15+ psi.
If it is ported, and your boost levels are stable at ~6psi, then you should only be looking to go up to about 8psi on a stock fuel system. An Rtek 1.7 (www.pocketlogger.com), two 720cc injectors & a better fuel pump will only be around $400. You can get a decent manual boost controller for cheap too (ball-and-spring type only), and then should be able to make 10-12 psi safely. A wideband O2 sensor can be had for around $250-300 too. A BOV isn't really needed. It's not going to make the car any faster.
Old Jun 26, 2009 | 11:50 AM
supercayo's Avatar
Get a microtech ecu
Old Jun 26, 2009 | 12:46 PM
project3328's Avatar
yea get some sort of ecu
Old Jun 26, 2009 | 01:24 PM
fdfreak's Avatar
power fc or full exhaust
Old Jun 26, 2009 | 07:59 PM
Lucky-7xl's Avatar
get suspension or exhaust = D
Old Jun 29, 2009 | 10:11 AM
Aaron Cake's Avatar
Engine, Not Motor
He has $800 and you people recommend a standalone? Get real. It's going to be a minimum of $2000 to put in any standalone and tune the car properly.
$800 can buy a new set of shocks and springs. That's a pretty good bang for the buck.
Old Jul 2, 2009 | 12:43 PM
13B-ADDICT's Avatar
if your going to upgrade boost id recommend,Intercooler and piping,BOV,wastgate.But really dont forget bout the fuel injectors and pump.a standalone would have been a perfect combination with all of this.couldve had so many tuning possibilities.Go to the dyno and man whatever im just goin on.
Sethix
Nov 3, 2017 11:48 PM
LongDuck
Oct 7, 2015 08:12 PM
ChanBagz
Sep 17, 2015 03:36 PM
