ok bout done with this flooded. now seems seized.
Old Jun 21, 2009 | 08:23 PM
bobbymikeh6969's Avatar
ok my mechanic told me to pull the plugs and remove the egi fuse and push the gas to the floor and clear all the gas i did so and have done it three times now. the batery is charged and now it just clicks it wont crank anymore does this mean it is seized?
Old Jun 25, 2009 | 08:29 PM
farberio's Avatar
NASA-MW ST4
It means the starter might be dead. Take it off and have an auto parts store test it.
You should also have the battery tested as well.
Old Jun 26, 2009 | 10:02 AM
Kentetsu's Avatar
Put the car in nuetral, and then see if you can turn the front pulley by hand. This will be even easier to do with the spark plugs out.
If the motor still turns, then remove and clean all the connections at the battery and the starter.
Also, to help get a rotary started, you can dump an ounce or two of Seafoam down the carb (if equipped) or use a turkey baster to shoot a little into the upper spark plug holes. This will get a flooded rotary going in no time flat...
PhillyFC
Aug 21, 2015 06:36 PM
racerfoo
Feb 5, 2006 09:34 AM
