Leaking Injectors
Old Jun 18, 2009 | 07:27 PM
OutCold's Avatar
Leaking Injectors
So i got a vacuum leak wich im pretty sure is from my injectors on the secondary rail, just too get it straight if im wrong im talking about the rail that runs under/through the uim pipes.
I sprayed starter gas on em when i had the engine running and the rpm shot up too the normal ground map idle. When im looking at the stock injectors, should they have rubber o/rings in both ends or just in the end that sockets into the rail?
Old Jun 18, 2009 | 09:15 PM
BASTARD's Avatar
there should be a little o-ring at the top and grommet at the bottom... there is also a rubber grommet on the top of the injector that the rail "sits" on
Old Jun 18, 2009 | 09:17 PM
BASTARD's Avatar
Old Jun 19, 2009 | 02:40 AM
OutCold's Avatar
So im not supposed too have 2 o-rings at the bottom of the injectors like this picture tells me too?
Old Jun 19, 2009 | 06:04 AM
OutCold's Avatar
i really wish i could edit my own messages...
I put the UIM and intercooler back together and started it up, it ran fine until a few minutes after when it started too jump on the rpm again, i stopped by the side of the road and sprayed some engine-starter gas towards the sec.rail injector area and the engine responded too it.
What i dont get is: Why doesnt it jump on the rpm all the time and not until a few minutes after if there is a vacuum leak there?
I put 2 o-rings on the bottom of the injector and that didnt help, if there is supposed too be o-rings there should the insulator be placed between them?
Old Jun 19, 2009 | 12:24 PM
BASTARD's Avatar
those are the defusers that sit down inside the injector holes... yes, they should have their own o-rings
Old Jun 19, 2009 | 12:26 PM
BASTARD's Avatar
Old Jun 19, 2009 | 12:29 PM
OutCold's Avatar
well both the rubber on my injectors and on the secondary rail is leaking now so i guess i gotta fix that, while im in there i gotta take a look at the primary rail as it seems too be the cause too the initial problem
Old Jun 19, 2009 | 02:57 PM
BASTARD's Avatar
he isn't just talking about the fuel rail... he is talking about the injectors... you can easily have a vacuum leak between the injector and the engine/manifold...
one other thing it could be is a bad lower intake manifold gasket
Old Jun 19, 2009 | 04:54 PM
OutCold's Avatar
u mean the gasket between the UIM and LIM? that gasket is brand new, engine is brand new. it doesnt react until i spray the starter spray into and towards the primary fuel rail, and no the rail isnt leaking but there is a major leak on the rubber connecton going down infront of the engine from the secondary rail and also i got fuel guzzling up from the front injector, maybe the rear one aswell, im having a "buddy" come over on monday too have a look and he might be able too help as he has some extensive experience on these engines. i hope that we can fix it then, guess ill just mess around with the new stereo in the meanwhile hehe
ZaqAtaq
Sep 5, 2015 08:57 PM
gabescanlon
Sep 5, 2015 12:04 AM
FührerTüner
Sep 4, 2015 01:41 PM
