Boost creep?
Old Jun 16, 2009 | 10:36 AM
incubuseva's Avatar
Boost knob
Boost creep?
So I have a basically stock S5 jspec that I just put in. After running around in it for a good long while I gave it some gas. I hit 14 psi! Is this boost creep or is this what the stock motor is supposed to do? I'm guessing this is also a good way to make it go pop.
Old Jun 16, 2009 | 10:38 AM
nitronatefc's Avatar
Topless, & Barely Legal
A stock S5 boosts around 8psi, maybe 9
So what does "basically stock" mean? Obviously this is the source of your problem.
Old Jun 16, 2009 | 08:22 PM
incubuseva's Avatar
Boost knob
Intake and catback. That's the not stock part. I may have left a hose unconnected? But I dunno yet.
Old Jun 16, 2009 | 08:33 PM
maac0953's Avatar
well a restricted exhaust is what keeps the boost at that constant stock boost.
5.5lbs for s4 and 8lbs for s5 TII's
since you have a free flowing exhaust now you freed up the restriction and now your over boosting. have fun running LEAN
buy a walbro 255, that should help some. and a wideband.
Old Jun 16, 2009 | 09:10 PM
RotaryRocket88's Avatar
Top Down, Boost Up
Port the wastegate. Anything else is ignoring the problem. In my experience, a catback is usually not enough to cause boost creep, but a new intake is. The stock intake is very restrictive on TIIs.
MMoore4545's Avatar
port your wastegate,
or
get a new manifold
an external wastegate
and a boost controller.
http://fc3spro.com/TECH/HOWTO/KWG/kwg.html
Old Jun 16, 2009 | 09:18 PM
rotaryat16's Avatar
rotoryat16....4 life...
Get a boost controller and just turn the boost down...
Do u have a fuel cut defencer??
If u run that open u will pop!!
Old Jun 16, 2009 | 09:31 PM
MMoore4545's Avatar
A boost controller won't address the issue. it may help a little.
The issue is, that the internal wastegate can't bleed off the exhaust.
It's a physical limitation.
The only real way to limit the power that's produced by the turbo is to port the wastegate.
Old Jun 16, 2009 | 10:47 PM
1SWEET7's Avatar
Now With 10th AE Fun!
Yeah boost controllers cannot lower boost. Port your wastegate out or you could end up blowing your engine. Here is a pic of what my stock S4 wastegate unported and ported looks like. Notice how small the stock hole is.
Old Jun 17, 2009 | 12:42 AM
incubuseva's Avatar
Boost knob
Heh so I'm a ****. When I took off my turbo to port it (never got around to it) I forgot to hook up that vac line right by the intake of the turbo. So basically I was running at full boost. Luckily I didn't go too crazy but I got close. I have a buddy who blew at 15psi and I hit 14... Lesson learned. I will port the waste gate soon and get a boost controller. First thing I did was get an fbcd. I have an extra too.
Shainiac
Jul 17, 2019 02:20 PM
Bauer778
Nov 4, 2015 04:42 PM
zxrazorxz
Sep 14, 2015 07:21 PM
High_Carb_Diet
Power FC Forum
Sep 5, 2015 09:07 AM
