Opinions on these wheels for my FC
Old May 12, 2001 | 12:52 AM
asherwood's Avatar
Question Opinions on these wheels for my FC
What do you guy's think about these wheels for my '91 NA? Kosei Racing Senaka 17x7 with Khumo ECSTA Supra 712 at 215-45-17? They have a +35mm offset, and I thought the stock rims have +42mm offset. Will there be any problems with fitment? Any idea how heavy they are?
Al
Old May 12, 2001 | 02:19 AM
ARD T2's Avatar
Don't do it man. I sell rims and tires for a living. They're my passion. The problem with putting a "knockoff" rim, universal boltpatterns etc., on the FC's or D's or 300z's, is it doesn't space out right to the fender. As well as the tire being skinny as hell.
I know they make certain applications in an 8" width, with a 40mm offset. This is ideal. You can rotate your tires if you run a 225/45/17 front and rear, it'll look better and is only 9 revs/mile difference in favor of topper speed. I reccomend the M3 setup. Depending on your suspension and ABS or not, you can run a 225/40 or 45 up front and a 245/40 in rear. Looks more aggressive.
Oh yeah, I own four FC's and do multiple test fitments on them constantly.
The ultimate in a 17" would be a 9" or 9.5" rim, w/ a 35-38mm offset, 8's the biggest most common fitment for the front. An 18*9 would be sweet, with a 17 up front. I got some 3 piece ssr's staggered on my GTX, 18*8.5 w/ 255/40/18 in rear and a 17*8 w/ a 225/40/17 up front. My buddy has 17*8 and 17*9.5 on his '87 n/a. 255/40 in rear w/ racing beat springs&illuminas, he drives like a maniac, and it still doesn't rub.
I plan on getting some 18*9 OZ Superleggeras pretty soon. They're forged aluminum, less than 18lbs.
Anyways, I'd hook you up but you're far away. If you PM me your budget, I can give you advice on weight, size, tires, and some numbers you can take to negotiate with your local distributor.
Good Luck, Rishie
Automotive R & D
[This message has been edited by ARD T2 (edited May 12, 2001).]
Old May 15, 2001 | 01:11 AM
asherwood's Avatar
Hey Rishie, (or others interested) With the wheels that I posted above will 225-45R17 fit front and rear?
I checked my stock rims and they appear to have a +40mm offset, so the Kosei's are closer than I thought. Any idea what they weigh?
Al
whinin
Sep 5, 2015 11:52 PM
