where could i find mods
Old Jun 12, 2009 | 01:02 PM
ReaperFC3's Avatar
FC3+350z=Ford Focus?
Smile where could i find mods
hey im new to rotarys own it for 1 year know n cant find any performance for my second gen rx7? where could i find performance for it?
Old Jun 14, 2009 | 04:02 AM
Rx7_Nut13B's Avatar
Red Neck Tony Stark - C2
That is a great NOOB post, if you want information like that you need to provide information
Ok we know it is a FC but there is/are two types S4/S5 then you have Turbo/NA, what type of mods do you want.
You will not go far unless you provide as much information as you can when you post something on here.
Old Jun 14, 2009 | 12:50 PM
Handful's Avatar
International Expert
Full bolt-ons!!
It depends what your goin for. HP? Suspension? Better Stereo? what kind of performance?
Old Jun 15, 2009 | 08:40 AM
Kentetsu's Avatar
www.re-speed.com for starters...
Old Jun 16, 2009 | 01:49 AM
ultrataco's Avatar
r o t a r y
Make sure you know what your doing before you go modifying anything. And always do maintenance, tune up and reliability mods first. Get the car running good, or mods will likely make it worse.
That said, here are a few places to get stuff:
http://www.rx7.com/
http://www.racingbeat.com/
http://www.mazdatrix.com/ (mostly OEM parts but some aftermarket stuff, too.)
Good luck. Since you're new, post a pic or two of your car. We like pics.
Old Jun 20, 2009 | 12:20 PM
ReaperFC3's Avatar
its a S4 na and i want it for touge
Old Jun 20, 2009 | 12:24 PM
ReaperFC3's Avatar
it runs like new and i do alot of maintenance. i only want to push 380 to the wheels i dont want to go crazy for hp i just want it to handle better than my friends 03 911 turbo is it possible
Old Jun 20, 2009 | 03:01 PM
trblsmeFC's Avatar
I don't wanna burst your bubble but no amount of bolt-ons will net you 380rwhp, you will have to go boost. This isn't a 350 chevy where you can buy a intake and a set of headers and go. The handling should be easy to achieve tho.
Old Jun 21, 2009 | 10:24 AM
Aaron Cake's Avatar
Engine, Not Motor
I don't really know what "touge" is but if you want 380 to the wheels, it is not going to be a good idea to stay naturally aspirated. It can be done but will require a combination that is unstreetable by any definition.
380 to the wheels can be achieved by a moderate turbo upgrade (GT35R is one of the best turbos for stock and street ported 13Bs, use the biggest T3 hotside you can find or a T4 .89). Of course you should probably start with the TII engine and you should have the TII drivetrain as well. It will require a standalone and a full fuel system upgrade, front mount, etc. etc. etc.
A good set of shocks and springs will make a huge difference in how the car handles, and replace all the 20+ year old bushings and joints. It really doesn't take much to make these cars handle like no other but as I have not driven a 2003 911 I can't compare.
Old Jun 21, 2009 | 11:36 PM
ReaperFC3's Avatar
yea thanks for the help, and i wasnt gonna keep it na i was thinking about going turbo, so should i get the T2 engine, or could i slap on a turbo on a NA engine?
Old Jun 22, 2009 | 12:05 AM
thejallenator's Avatar
well slapping a turbo onto the NA motor is a bunch of work. way easier to swap motors, or so i've heard. its possible but jsut very time consuming
Old Jun 22, 2009 | 12:07 AM
ReaperFC3's Avatar
what do you have to do thats is a bunch of work
Old Jun 22, 2009 | 09:44 AM
-CON-'s Avatar
I would just buy a car with 380hp to the rear. It'll be cheaper and easier since you don't know much about it.
Old Jun 22, 2009 | 07:29 PM
ReaperFC3's Avatar
but i like my fc3
Old Jun 22, 2009 | 07:39 PM
trblsmeFC's Avatar
there are alot of threads on adding a turbo to a NA motor/rx with lots of pics and good info, there is more then one way to turbo a NA motor/rx, you can make it as difficult/detailed as you want to, and its all about how comfortable you are about doing the majority of work yourself
Old Jun 22, 2009 | 11:44 PM
-CON-'s Avatar
but i like my fc3
And how much money are you willing to spend ? It's not that easy to make 380 reliable HP out of old n/a car. It could be done if you got mechanical skills and you can do it much cheaper, if you ain't got that, then you gonna have to pay someone big $ to do it for you. What do you have so far done to your car? Is the engine old stock? If it is it is ain't going to hold the turbo. It involves a lot of **** and that including electrical. I don't know, a fun car not always means big HP.
A lot of **** involves to have your old rx to be near with your friends 03 911 turbo. But if you aiming that direction and you like second gens. I'd start with a factory turbo rx, and, the newer the better. Trust me I've done turbo conversion and I would never do it again. Anyway turbo, non turbo, for performance you'll need a good ECU, that will make you HP, it's a very good start, you change your pipes or intake you need to tune your ECU. If you going with turbo DON'T buy Chinese kits, get a good heavy manifold and good expensive turbo, once you get everything it's gonna cost you just as much as in good shape turbo II rx , that already have everything and with better exhaust and intake, and more boost , it could make you easy 250+ to the rear wheels which would be more fun than trying to slap the turbo on to the n/a. But it is up to you, I just want you to see the picture of what it takes to do what you want to do! Well good luck
Old Jun 23, 2009 | 09:11 AM
Aaron Cake's Avatar
Engine, Not Motor
There is no "slapping" a turbo onto an NA engine. It is a lot less difficult then most people assume or say. I would even venture to say that if you have the skill, equipment and knowledge, then it is rather easy.
However, for most people it is far better to do a standard TII swap.
See the 2nd gen FAQ for details on both approaches.
Old Jun 23, 2009 | 11:39 AM
-CON-'s Avatar
Whatever that means !
I've done it and that car still drives to this day.
Old Jun 23, 2009 | 01:10 PM
Aaron Cake's Avatar
Engine, Not Motor
By "slapping" I mean you don't just bolt on a turbo and go about driving.
As you may recall, I happen to have a turbo-NA RX-7.
Old Jun 23, 2009 | 11:33 PM
-CON-'s Avatar
Yeah I know a pretty cool one too, one of the best projects I've ever seen on the net.
What was yours best time in a 1/4 mile run?
Old Jun 27, 2009 | 09:42 PM
ReaperFC3's Avatar
Talking
i havent got it 1/4 mile run i want to use it for touge runs n the onyl upgrade i did to it was Racing Beat headers And mufflers, Tokico Suspension n thats pretty much it n im willing to spent money but i want to have pride to say i built it myself so easy way is T2 engine, so were could i get a T2 engine And Thanks for the Help It means Alot thanks
Old Jul 2, 2009 | 12:34 PM
13B-ADDICT's Avatar
get a t2 engine on rx7world.net or atkins rotary but its gonna cost an arm and a leg.Id tell u to stick with n/a if u want a challenge but since u doin togue.either way your going to need a roll cage and a lisence to race in certain tracks.also theres a lot of other crap u should just ask bout the qualifications and shiznit.but good luck.
Old Jul 2, 2009 | 11:40 PM
ReaperFC3's Avatar
Thanks for the help whcih is better throttle response
Old Jul 3, 2009 | 08:57 AM
Aaron Cake's Avatar
Engine, Not Motor
Throttle response depends entirely on the tune. In stock tune, both engines don't have that instant throttle response you are probably looking for because of an old ECU and probably worn out sensors/injectors. With a well tuned standalone throttle response is instant.
Old Jul 3, 2009 | 11:26 PM
ReaperFC3's Avatar
so which ECU should i get
streetlegal?
Mar 17, 2022 02:46 PM
Skeese
65
Mar 28, 2017 03:30 PM
fd3sguyy
Aug 16, 2015 03:20 PM
