gas smell at warm up
Old May 31, 2002 | 07:50 PM
Silkworm's Avatar
Has been.. hangin' around
Replaced your pulsation dampner yet? I bet you will soon. Search the forum for pulsation dampner, plenty of threads on how to fix.
PauLC
Old May 31, 2002 | 08:03 PM
Matlock's Avatar
I have the same problem too. I'm not sure if its the pulsation damper or just the warm up stage.
Old May 31, 2002 | 08:26 PM
seveninphilly's Avatar
on the road to insanity
These are the early signs of PD failure the high pressure from the start up cycle makes it leak but at high speeds when the pressure is the same you don't notice it as much because its being wisped away. by the air flow
Old May 31, 2002 | 08:34 PM
Old May 31, 2002 | 09:27 PM
RexRyder's Avatar
that happens to me too, i'm not sure if its the PD tho. the engine would have blown up by now the way i drive it
Old May 31, 2002 | 09:38 PM
RETed's Avatar
The post is in the archive, but I finally managed to put it up in my FAQ section...
http://fc3s-pro.com/TECH/FAQ/pd.htm
-Ted
Old May 31, 2002 | 09:51 PM
telus.net's Avatar
After checking out Ted's page, I am kind of scared!!
Old May 31, 2002 | 09:59 PM
RETed's Avatar
Check out the archived thread...
https://www.rx7club.com/forum/showth...threadid=60160
I've updated my page to add a link at the bottom to the above thread also...
-Ted
Old May 31, 2002 | 10:16 PM
telus.net's Avatar
Those bastards crated a nice, high output, light weight, long lasting engine, but it is always those tiny ***** that screw up the wet dreams!
Old May 31, 2002 | 10:26 PM
Raymr's Avatar
I had this problem and it wasn't the PD. It was a tiny pinhole in the hose that goes to the fuel rail, only visible when the engine was cold.
Old May 31, 2002 | 11:22 PM
Silkworm's Avatar
You damn well should be.
Old May 31, 2002 | 11:24 PM
SonicRaT's Avatar
Super Raterhater
If it's not the PD (check incase!) it might be the shift boots are torn allowing fumes from your exhaust in.
Old May 31, 2002 | 11:59 PM
silverrotor's Avatar
Although I haven't checked out Teds page yet, the PD acted up on me to. For a S4 PD make sure the screw Is on tight than apply a bead of RTV sealant. That should be sufficent enough to prevent the notoriuos screw from ever backing off again.
You should also check to see your Charcoal Canister, at the passengers side corner, Is not cracked or/and the hoses are not pooped off.
Old Jun 1, 2002 | 12:17 AM
RETed's Avatar
Copper RTV!&nbsp Looks like my car!
-Ted
squirrels
Sep 1, 2024 09:52 AM
Aramir
Oct 18, 2015 02:39 AM
WyomingTII
Sep 28, 2015 10:32 AM
rattlehead
Sep 25, 2015 10:55 PM
