88 rx-7 will turn over but won't start
Old Jun 8, 2009 | 02:55 PM
lighttekku's Avatar
R.I.P Icemark- Lucky 7
VT 88 rx-7 will turn over but won't start
i recently purchased a 1988 rx-7 (13b), project car, i am totally new to the rotary world, so know that i may sound like an idiot. that being said. my rx-7 will turn over, but it will not start, i checked the spark plugs and wires and they all look great, i do not know much about this car's history, but i do know that it has been sitting for 2 years or more. i also know that it was regestered and inspected in 2005, one more thing is that the wiring harness is not installed properly, the wires have been cut and re-spliced back together, i do have a new harness that i am installing, but i am unsuer if the car should be able to start with out it.
thanks
geoff
Old Jun 8, 2009 | 09:52 PM
farberio's Avatar
NASA-MW ST4
Well, a motor needs.
1. Compression
2. Ignition
3. Fuel
Check them all for proper operation.
Old Jun 9, 2009 | 01:03 PM
414 RX7 RIDER's Avatar
zoom zoom
From: Milwaukee...Home of the Brewers and the Bucks
Its probably flooded. To de-flood it first making sure your battery has a full charge, take out your spark plugs, then turn the key for about a minute, then put new spark plugs, or at least clean the old ones, reinstall them, and it should start. It could also be other problems, like low compression, no spark or no fuel like farberio said, but I would try what i said, of course first checking if it has spark.
Old Jun 9, 2009 | 09:41 PM
klint's Avatar
hp=fun
Fueland spark
i recently bought a t2 it sat for a few years and i had major fuel issues the gas had jelled and plugged everytning up make sure you check your pump, pump filter and inline filter and make sure you drain any remaining old gas, there's a a drain plug in the bottom corner of the tank as far as wiring good luck with that may you have success
Old Jun 13, 2009 | 04:11 PM
Gene Wollen's Avatar
won't start
If its been sitting for 2 years the injector seals are probaly leaking. Can you smell gas when you check the dipstick?
Old Jun 13, 2009 | 11:12 PM
wolfwood09's Avatar
i think this should do it...
Old Jun 26, 2009 | 11:55 AM
supercayo's Avatar
Put new sparks on it dont clean them and try the unflood procedure
Old Jun 26, 2009 | 12:23 PM
Defiantone's Avatar
I recently bought an 86 na and it sat 5 years and the same problem. I just drained the gas. Put new gas in and had to change the fuel pump it was seized. After I put in a new used one it fired right up
Old Jul 12, 2009 | 12:15 PM
lighttekku's Avatar
sorry guys haven't been on in a while.
to answer your question, yes, i do smell gas when i check the dipstick, i'll get the injectors checked out, thanks
Old Jul 14, 2009 | 11:40 AM
His&HerFC3's Avatar
i just picked up a 87 NA and the previous owner said something about coolant leaking into the engine thats why it does not run but it turns over just wont start is there anything i can check to see what the real problem is sorry for the newb ?'s but im new to the rotary engines would this be the same as a blown head gasket
Old Jul 16, 2009 | 07:21 PM
True2RX7's Avatar
I just talked to someone today about that, he said if there is white film in your exhaust that means the coolent is getting in there. He also had a whole book filled with pages of information (detailed) that he got somewhere on this site. I myself am gonna start looking for it. I checked here for similar problems. These rotorys are cool, but come with so many differant issues lol.
Jun 26, 2016 10:21 AM
alphawolff
Nov 17, 2015 05:57 PM
PhillyFC
Aug 21, 2015 06:36 PM
Im faster
Aug 19, 2015 02:57 PM
