idle wrongs
Old Jun 7, 2009 | 06:54 PM
dakota's rx7's Avatar
idle wrongs
first i have an 86 N/A i have and idle prouble it will start up and go to 3000 rpms and then die right after that but it will start right back up. what is the proublem???? it has good fuel pressure all the way around.
Old Jun 8, 2009 | 08:55 AM
Aaron Cake's Avatar
Engine, Not Motor
Big vacuum leak.
Old Jun 8, 2009 | 09:12 PM
ok i know theres a big vacuum leak on the intake manifold
Old Jun 8, 2009 | 09:31 PM
Asmar's Avatar
TeamDori.com
I'm having the same problem... Kinda...
Old Jun 9, 2009 | 10:30 PM
should i jus buy new intake caskets and see what that does for me?
Old Jun 10, 2009 | 10:07 AM
Aaron Cake's Avatar
Engine, Not Motor
Track down the leak using standard techniques. I like to get the engine running and warmed up, then squirt water around the engine bay. You will find the vacuum leak when the engine sucks in the water and changes tone.
Old Jun 10, 2009 | 12:40 PM
ok thanks
Old Jun 10, 2009 | 08:47 PM
ya i cant the engine warm because the car only runs for 5 seconds
Old Jun 11, 2009 | 09:14 AM
Gene Wollen's Avatar
Find a shop that uses the smoke system to test for vacuum leaks. the engine does not have to be running.
Old Jun 11, 2009 | 10:38 AM
well i found the vacuum leak its on the lower intake manifold
Old Jun 11, 2009 | 01:39 PM
Handful's Avatar
International Expert
Its it a seal that needs to be replaced? if so replace it. Or if its a crack then replace the intake. The hard part is finding the leak. The repair should be self explanitory after that.
24seven_dada
20
Nov 10, 2018 12:03 PM
The1Sun
Sep 18, 2015 07:13 PM
The1Sun
Sep 15, 2015 04:45 PM
The1Sun
Sep 7, 2015 10:21 PM
