What's needed to mount a rotary in the rear end?
Old Jun 4, 2009 | 06:38 PM
5star's Avatar
What's needed to mount a 20B rotary in the rear of somthing like in this vid?
http://www.youtube.com/watch?v=NTelrwuFsZM
<object width="425" height="344"><param name="movie" value="http://www.youtube.com/v/NTelrwuFsZM&hl=en&fs=1&"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/NTelrwuFsZM&hl=en&fs=1&" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="425" height="344"></embed></object>
Old Jun 5, 2009 | 01:33 AM
Scrims's Avatar
Hide the pinball machine
A massive amount of custom fabrication. Pretty much everything would need to be custom.
Old Jun 5, 2009 | 08:07 AM
Go48's Avatar
Money, money, money, lots of time and a skilled fabricator/mechanic. And more money!
Old Jun 5, 2009 | 01:18 PM
Aaron Cake's Avatar
Engine, Not Motor
With a tube chassis like that, it's about a simple as welding on mounts and then hooking everything up. You would need to figure out how to mount it to the transmission (bellhousing adapter) and then find clutch components you can mix and match to mate it all up.
This falls under the category of "If you have to ask...".
Old Jun 5, 2009 | 02:43 PM
5star's Avatar
I'm not talking about chassis fab I can do that. I'm talking about if I buy a rx7 engine or 20b with the tranny off ebay they come set up to be mounted in the front. What tranny parts are needed to mount the rotary in the rear and where can I find them??
Old Jun 5, 2009 | 04:34 PM
Aaron Cake's Avatar
Engine, Not Motor
It depends on which transmission you are looking at.
There are adapters on the market to fit the rotary to several Porsche transmissions so that is the place to start. Look up Kennedy Engineering.
Old Jun 6, 2009 | 02:54 AM
Kentetsu's Avatar
How do you mount a rotary in the rear end? You have to sneak up behind it...
Anyway, at Deals Gap this year there was a 20b 911. Awesome car, and proof that it can be done...
Old Jun 9, 2009 | 02:18 PM
simonrex55's Avatar
i have a 12a in a 912, very simple with an Kennedy engineering adapter plate.
Old Jun 10, 2009 | 06:51 PM
mikem1959's Avatar
fat and greasy
Most sand buggies use beefed up vw trans axles out of a vw bus.I am getting ready to build a 12A VW TRIKE let me know how you make out.Kennedy enginering products sell adapter plates for around $500 they also sell clutch set ups .
check out volks-swap
