my car's running @ 15.3V during idle.... ideas!?
Old Jun 2, 2009 | 12:17 AM
1/4 ohm surge's Avatar
registered fc3s
Lightbulb my car's running @ 15.3V during idle.... ideas!?
Two nights ago when I was driving on the freeway all my warning lights ( in my 89 turbo II ) came on and my cluster was extremely bright all of a sudden, for a second thought my battery was dead but realized right away that I'm still driving on the road and my car was running fine. (of course my cluster was still bright as hell)
So I pulled over, restarted the car and it was doing the same thing, but this time all the warning lights would come on then fade away.. pretty much it was tripping, and my windshield wiper came on by itself while I was driving away... I was like WTF ?? I had to get home so I took local, car still drives fine I made it home, but, my warning lights were tripping the whole time!
Today I drove around again and it was doing the same thing. Finally got a meter tested 15.3 volt during idle... I'm going to get new alternator tomorrow (maybe the voltage regulator inside is F.up..? I'm thinking ).... but, one thing I need to mention is that, if I turn on my AC, or headlights... it would trigger something ( a circuit perhaps ??) and my warning lights would go away... until i turn whatever off then come right back on... so, it's almost like whenever I put a load on the system it trips it out ? IDK...
But I was wondering.. could it be anything else that triggers it ( besides the voltage regulator inside alternator if it's even the cause) ? Could the cause be something else....? if so... what could it be!!
ANY HELP OR IDEA WOULD BE GREATLY APPERICATED !! THANKS !! I need to get this fix... is CRAZY driving around at night... with tripping warning lights... and possible fry everything else.... ^_^ seriously.
Old Jun 3, 2009 | 09:40 AM
Aaron Cake's Avatar
Engine, Not Motor
Make sure the two wire connector is plugged in at the back of the alternator.
Old Jun 3, 2009 | 01:00 PM
bose's Avatar
Seems like an alternator to me.
Old Jun 3, 2009 | 02:39 PM
RotaryRocket88's Avatar
Top Down, Boost Up
When all the warning lights come on, it means one of two things. Either the plug on the back of the alternator is loose or unplugged like Aaron mentioned, or there is a problem with the alternator's voltage regulator. The lights coming on is part of the warning system. Since you measured 15.3V, I'd say it's the second option.
Old Jun 3, 2009 | 05:32 PM
Kentetsu's Avatar
One other cause would be the belt coming off.... Probably lost your regulator, but it might also pay to check all the battery connections at the battery and at the starter. You can also take the alt to most any parts store for free testing...
Marty RE
Aug 29, 2015 07:51 AM
smikels
Aug 18, 2015 01:26 PM
ashleymiche
Aug 14, 2015 12:59 PM
baconflavored
SE RX-7 Forum
Aug 12, 2015 12:07 AM
