Haltech Wierd issue with injector staging!
Old May 28, 2009 | 09:11 AM
E Dogg's Avatar
FC Boneyard
First some some background
I just did a rebuild, on a car that already had an E6X setup running 550/1600's
After doing some break in i decide to gingerly creep into boost, but as soon as i hit the point where the secondaries come on my car leans out like crazy and stalls. OK so i think i don't have enough fuel but adding some to primaries or secondaries doesn't help at all... its so lean it wont fire at all and bogs down, as soon as i let off and go back to where only the primaries are working i get my normal AFR's again.
By doing some some trial and error with the help of a friend with more Haltech/Rotor experience - he noticed that even with the secondaries set to 0 ms across the board- whenever we specify the staging to begin 4th bar, 10th, 14th etc that's when the car leans out. I have double checked my secondaries are connected and wired in the correct order and everything looks OK to me.
any ideas?
Old Jun 8, 2009 | 01:16 PM
E Dogg's Avatar
FC Boneyard
bump?
Old Jun 8, 2009 | 01:25 PM
classicauto's Avatar
Crash Auto?Fix Auto.
if you set the secondaries to 0ms (zeroing out the fuel map after the staging bar,yes?) then ofcourse its going to run lean
First, where was the staging bar set when you first had the problem? And what was the approx. on time on the bar BEFORE staging?
Second have you checked to make sure all your setting in the fuel setup page are correct? Ie. set to staging etc.
Old Jun 8, 2009 | 01:29 PM
E Dogg's Avatar
FC Boneyard
what i mean is i set the staging bar to -8psi where the primaries deliver enough fuel on their own. if the staging is set to 12th bar (0psi) i am fine, exact same map if i tell the 2ndaries to stage at -8psi i start to lean out at that same point even though i am using the same amount of fuel only from the primaries just as before- the only difference is when the haltech starts to use the map on the secondaries. The map and settings, injectors etc were all in place before i did a rebuild. the only thing that changed was i rebuilt the engine and rewired the injector connectors because the old ones didn't have the retaining clips anymore.
hope this makes more sense...
nothing changes but where my staging bar is set, as seen in these maps....
if i set the staging bar to 24 everythitng is fine on the primaries alone until i run out of injector lol
Old Jun 11, 2009 | 01:42 PM
E Dogg's Avatar
FC Boneyard
seems it was a voltage issue, i reran my power and put new ends on my battery cable, and re soldered the injector leads, now everything is working!
Old Jun 13, 2009 | 05:58 PM
Claudio RX-7's Avatar
EFI Tech Wannabe
The answer to your fueling problems are simply put, you are turning on the Staged injectors at the wrong point, and the way your fuel map is laid out for a 2bar MAP sensor, thats why that step is there halfway through the map. If you are you using a 3bar MAP sensor you need to basically roll that step back to the zero load point.
What is the rest of your setup?
Old Jun 14, 2009 | 11:34 AM
E Dogg's Avatar
FC Boneyard
i was changing the staging bar to troubleshoot the issue, normally it is near 0-1 psi
turns out i had several issues affecting voltage causing a drop when all 4 injectors came on- and that is why whenever my seccondaries were energized all 4 injectors would have issues.
Old Jun 14, 2009 | 05:01 PM
EFI Tech Wannabe
And what was that exactly? a shorted injector? incorrect current setup? alternator/power issues?
Old Jun 15, 2009 | 08:40 AM
E Dogg's Avatar
FC Boneyard
battery terminal and cable were sketchy, and my e-fan that pulls 20-25 amps was set to run at 181 F, so it was on constantly making it hard for the alt to keep up.
Queppa
Nov 18, 2024 03:47 AM
sYnth.
Aug 19, 2015 06:27 PM
