front suspension problem
Old May 27, 2009 | 02:33 AM
88fcdriver's Avatar
i have an 88 fc and i bought some ground-control coilover sleeves. now im having problems with the front suspension. i want to lower them more but i already set them to the lowest. and i still have about 2 inch gaps from tire to fender. i just want to know what i can do to fix this problem. i dont want to buy the strut lowering kit that they have for sale online. can i buy shorter springs? where? let me know please. thanks in advance.
Old May 27, 2009 | 09:24 AM
TrentO's Avatar
as long as the shock isn't bottoming out you should be able to go with a shorter spring. I've gone 1" shorter in the front to move the adjuster ring up to clear the rims in the front.
-Trent
Old May 27, 2009 | 11:41 AM
88fcdriver's Avatar
i was thinking maybe 4" inch springs and just raise the adjuster up a little bit. im going to get a little higher spring rate of course. but do u know a place online where i can get them? they dont have to be ground control.
Old May 27, 2009 | 04:59 PM
Josh18_2k's Avatar
wtf how do you have that much of a gap.. something is probably installed wrong.
with a 4" spring, you will be slamming the bumpstomps. i dont care how stiff teh springs are..
Old May 28, 2009 | 11:50 AM
88fcdriver's Avatar
i already contacted ground-control concerning this problem and i sent them pictures of the set-up. and they said theyre fine. so i dont know what to do anymore. maybe 5"?
Old May 29, 2009 | 03:37 PM
The Griffin's Avatar
Burning up Time
Maybe you can post some usefull information like what spring rate and free length spring /struts you have on there now? If it's a 6" spring already ,get ready to pony up some cash on camber plates or racing beat lowering strut tops to get the extra 1/2-3/4" drop like everyone else with that ground control kit on the oem type front struts(tokico/kyb/etc.) of a FC .
Old May 30, 2009 | 11:58 PM
88fcdriver's Avatar
theyre just 350 spring rate, 2.5 ID, and i have tokico illuminas. and yes they are 6 inches
Old May 31, 2009 | 11:18 PM
Josh18_2k's Avatar
a) illuminas are not valved for stiff springs. they will just bounce
b) the shocks WILL bottom out with a 6" spring.
handling will be pretty compromised. if you're just doing it for looks (slam the car), its probably not a big deal.
rotor_veux
46
Jun 12, 2018 10:39 AM
BNR34RB26DETT
42
Feb 28, 2018 11:27 AM
GrossPolluter
Aug 15, 2015 10:32 PM
