rats nest xperts! (not 56k friendly)
Old May 30, 2002 | 07:00 PM
Rx-7$4$me's Avatar
well, working on diagnosing my secondary boost issues, and I pulled off my pressure tank, and I noticed this before I touched anything. Is this supposed to be connected with somthing?!
please help ASAP!!
Old May 30, 2002 | 07:10 PM
Im 80% sure that is for a Auto tranz.
Old May 30, 2002 | 07:14 PM
StellarZ's Avatar
100% sure auto trans... dont worry about that one.
Old May 30, 2002 | 07:15 PM
Rx-7$4$me's Avatar
damn it !!! I thought I might have found my problem... sunofa bitch
Old May 31, 2002 | 10:03 AM
Mikey's Avatar
good luck man...that job isn't fun. but hey...mine worked the first time with no problems (knock on wood).
Old May 31, 2002 | 10:21 AM
JONSKI's Avatar
5yr member, joined 2001
I don't see it. What's disconnected, can someone circle it? I think it's that red-tipped one.
Old May 31, 2002 | 10:30 AM
rotorbrain's Avatar
fart on a friends head!!!
jonski, its the one that comes straight up for the automatic transmission application.
rx7$4$me: if youre okay with doing away with emissions in chicago then i would order the block-off plates from rx7.net and do away with all that. it is so much easier to do when you take the acv off. if you get the block off plates then you can do away with some of the solenoids and you wont have to deal with some of the crap. . . wait, you have to have a power fc to do that. nevermind. oops. they come with restrictors to put in the wires. its worth it if you ask me.
Old May 31, 2002 | 12:45 PM
spyfish007's Avatar
Yellow Dragon is no more
Yes that is for an automatic. You will also find one to the right pointed almost out and downward with nothing on it as well.
Old May 31, 2002 | 01:55 PM
amp's Avatar
amp
old yella
Rx-7$4$me
future reference...you can pretty much distinguish with the finish of a hard pipe whether or not it served a hose....remove a hose from an existing hardpipe and compare it to the one you question...difference is substantial...
Old May 31, 2002 | 02:18 PM
Toadman's Avatar
Nomad Mod
That good pic there shows 1/3 of the items for non-sequential turbo mod, the green turbo pre-control actuator(left), and the green wastegate control actuator(right). You might want to inspect that in-line green check valve.
ls1swap
Jun 3, 2024 03:25 PM
LongDuck
Oct 7, 2015 08:12 PM
Jetlag
Sep 29, 2015 06:52 AM
