how to fix a broken clutch switch
Old May 17, 2009 | 09:57 PM
kyleaudio's Avatar
Ling Ling
for those of you who have problems with your car stalling out when you are stopped in gear its probubally your clutch switch, so here is a cheap and easy fix that'll take no more then an 30 minuites.
first get under your dash and look at switch, if the button ist sticking out much then the spring inside has gone bad (it should stick out about 1/2"). so pull out the switch, bend the 4 metal tabs up holding the plastic connector piece in and pull out the gutts. then go to your desk/kitchen drawer or wherever you keep pens and get a click type pen (i used a skillcraft) take it apart and steal the spring (i'm not sure if all pens are the same so you might need to take apart a few to get the right size spring), then re-assemble with the new spring re-install and go for a drive!
thanks, kyle.
Attached Thumbnails how to fix a broken clutch switch-img_2939.jpg   how to fix a broken clutch switch-img_2942.jpg   how to fix a broken clutch switch-img_2943.jpg   how to fix a broken clutch switch-img_2945.jpg   how to fix a broken clutch switch-img_2946.jpg
Old May 18, 2009 | 12:06 AM
adam c's Avatar
Cheap Bastard
https://www.rx7club.com/3rd-gen-archives-73/cheap-bastard-fix-clutch-switch-495391/
Old May 18, 2009 | 09:16 AM
hanman's Avatar
Yea, old news.
Old May 18, 2009 | 10:57 AM
Monkman33's Avatar
Goodfalla Engine Complete
Its still not bad to have another thread with pictures, considering how things get swallowed by the forum sometimes.
Good Job Adam_C for the originally posted idea, and good job to the OP for figuring it out too.
Nothing wrong with redundancy, especially considering the common need for this fix.
Old May 18, 2009 | 11:46 PM
kyleaudio's Avatar
Ling Ling
yea, i wish i had found this earlier, i ended up buying a new switch and just tore the old one appart for for fun just to find that it was a cheap and easy fix. oh well. new pics and a bump for the old thread tho!
Old May 19, 2009 | 09:31 AM
TwinCharged RX7's Avatar
Built Not Bought
Top Answer: 1
I've noticed that i'll have to push the clutch a few times in order to get it to turn over. does the clutch switch fail gradually like this? or is it something else.
Old May 19, 2009 | 10:54 AM
kyleaudio's Avatar
Ling Ling
sounds like the spring broke and it cant push as hard as it used to, that or something sticky got in there so it cant come out like it should.
Old May 19, 2009 | 03:00 PM
Sgtblue's Avatar
Urban Combat Vet
Could be. But I think more frequently cleaning grounds, cleaning connections at the starter and battery terminals and making sure the battery is putting out full voltage helps more. It didn't take much on my car.
Th0m4s
Feb 26, 2019 02:04 AM
sYnth.
Aug 19, 2015 06:27 PM
tsmith94FD
Aug 16, 2015 05:41 PM
