Intercoolers... Greddy or M2
Old May 30, 2002 | 12:14 AM
agent712's Avatar
From what I've read M2 is probably the best smic? But how about the Greddy? The Greddy price is a lot more appealing. And do either come with any sort of box that directs air from the front facia directly through the intercooler so it's not as effected by the heat of the radiator?
Thanks
Chuck
Old May 30, 2002 | 12:16 AM
SexyRexyR1's Avatar
yes ... i know the greddy comes with a nice aluminum box that directs air through it ... no clue on the M2.
I actually like the look of the M2 intercoolers ... mainly the large one. Just looks nice. But the greddy is what i have on my car and it's cool.
Old May 30, 2002 | 01:20 AM
cruser's Avatar
Go with the M2 unit. It has a fiberglass duct that takes air to the ic. I highly recommend the M2 medium. Works excellent for me.
Old May 30, 2002 | 01:34 AM
artguy's Avatar
WTB** Very Low Miles 94-95
the greddy gets what I like to call the mod befor you do the right mod comment..... "you didnt get that little greddy did you?"
I was going to get the greddy..its so affordable in comparison...its just too small for me. If you arent running high boost or modding the hell out of your machine it will do fine I am sure.
jason
Old May 30, 2002 | 06:11 AM
Rotary Master
Just spend the money and get an M2, if you want a cheaper one, get a used PFS IC, but don't waste your money on the Greddy.
Old May 30, 2002 | 07:43 AM
GsrSol's Avatar
Z06 powered FD
The Greddy is just too small unless you stay near stock.
Old May 30, 2002 | 08:36 AM
Mahjik's Avatar
Mr. Links
Re: Intercoolers... Greddy or M2
Thanks
Chuck
It really doesn't matter a whole lot with stock twins turbos.... Either one is going to do the job and they are both better than the stock IC. It just depends on the the amount of work to fit it in (and how much money you want to spend).
GReddy is pretty close to stock fitting (some piping changes I think), the M2 needs a little more work to get it installed (I believe).
Old May 30, 2002 | 10:00 AM
neo_omega's Avatar
***Moderator***
If anyone interested in the M2 SMIC, I'm thinking of selling mine.
Old May 30, 2002 | 10:12 AM
maxpesce's Avatar
Ex fd *****
The M-2 WON'T fit w/ the stock airbox - it requires a narrow intake setup like M-2s or Petits etc.
Old May 30, 2002 | 10:13 AM
neo_omega's Avatar
***Moderator***
btw, I will sell my M2 air box too
Going single
Old May 30, 2002 | 11:06 AM
I LOVE the M2 IC's but I gotta ask.......for the money they want for it ($1500 beans) isnt a Greddy 2 row FMIC($950) a better way to go??? I mean we're talking $550 difference here and no matter how you look at it ALOT of ppl will tell ya you shld of gone w/ the FMIC.
ANYONE?
In terms of SMIC vs SMIC, I dont think they even compare just by looking at the size difference.
Old May 30, 2002 | 12:01 PM
m2
will it fit with the apex intake?
Old May 30, 2002 | 01:30 PM
enuttage's Avatar
Chicharrones Rule!!
I'm sure I'll get shot down on this one, but I'm using the GReddy SMIC on my single-turbo ~350rwhp setup.
I specifically asked RP about using the not-so-large IC in my particular setup. One phrase was uttered by them -
"Diminishing returns."
Size means nothing after a certain point. Now I'm not pretending to know when the diminishing returns begin, where the peak surface area is, etc. I just trust RP to give me the right advice on these things.
If anyone *does* have information on this, I'd love to see it. And I'm not talking about how much airflow, or surface area an IC provides. I'm talking about airflow, SA, and when you stop gaining any significant benefits from a bigger IC.
Physicists, gearheads? Got any idea on this one? Otherwise to me, it's all just "bigger is better".
-E
Old May 30, 2002 | 03:13 PM
ronarndt's Avatar
M2 vs Greddy SMIC
agent712- depends on how you are going to mod your engine and how much air volume you need to address. If you have a monster single turbo, obviously you need more IC cooling capacity. If you have the stock twins- well maybe the GReddy is adequate. If you put too large an IC on in relation to your turbo's output (don't think the M2 medium will do this), you will experience pressure drop, although the cooling capacity will be greater. The GReddy is larger than the stock IC and fits with little banging or cutting. The M2 is larger yet but will require some more work to fit properly. There is a table someone on the forum did with the interior volumes of the major manufacturer's ICs which compares stock to GReddy, Blitz, M2, Pettit, etc. I have had the GReddy SMIC for about two years and have been satisfied so far. I don't routinely do drags, but run 14 psi. If I decide to upgrade further, I probably will go with either a FMIC or one of the monster SMIC which require removing the stock air box and carrying the battery on your passenger's lap.
enuttage- that point of dimishing returns would be great to know. If you put the air volume from a twin or single turbo into an IC with the volume of an aircraft hanger, it would probably cool it perfectly, but there would be no boost pressure. There must be some sweet spot where you get the most bang for the buck.
Old May 30, 2002 | 03:25 PM
enuttage's Avatar
Chicharrones Rule!!
Re: M2 vs Greddy SMIC
Exactly! Of course if we knew what the sweet spot was, then marketing would be nearly pointless, wouldn't it?
I'm still *very* curious about this. And BTW, it's nice to know that someone else using the GReddy at 14psi is happy with it. I'll be running right about that level also, if I can ever get the A/C fixed and then break the damn thing in.
-E
Old May 30, 2002 | 03:28 PM
agent712's Avatar
neo omega, please e mail me the details about your intercooler and how much you want for it.
Basically, I want to do put on the best bang for my buck intercooler wise. I don't want to spend a fortune, and don't want to put something on that isn't going to make that big of a difference either. I'm really torn between the M2 and Greddy... I really would like to see some hard numbers of how much better the M2 medium smic is than the Greddy smic.
Thanks
Chuck
Old May 30, 2002 | 09:00 PM
kdamer's Avatar
neo omega - which M2 box is it? CF or Aluminum? I am interested. Check your PM.
eplusz
15
Oct 7, 2015 04:04 PM
