89 fc questions for a newborn rotor head
Old May 6, 2009 | 01:19 PM
dawson89fc's Avatar
my oil smells like gas....do these engines normally have this trait??? also when i rev and let off it pops through exhaust sometimes.....what would cause this??? engine still has loads of power and accelerates quite nicely
Old May 6, 2009 | 04:10 PM
Aaron Cake's Avatar
Engine, Not Motor
The oil smell can be common. Check the function of the PCV system.
If the car is popping, then it may be running a bit rich which can also explain the oil smell. Find out when the last full tuneup was and if it has been a while, perform one.
Is the car stock? If parts of the emissions system have been removed or bypassed the popping will be the result.
Old May 17, 2009 | 07:13 PM
dawson89fc's Avatar
car isnt completely stock......centerforce clutch...racing beat polished dual stainless steel exhaust.....koni shocks,eibach springs, apc air filter on stock piping, fresh plugs,ngk wires, so i am still clueless on it
Old May 18, 2009 | 10:50 AM
Aaron Cake's Avatar
Engine, Not Motor
You are getting the popping due to the exhaust.
Old May 18, 2009 | 01:56 PM
thejallenator's Avatar
if the oil isnt fresh over time it will break down and start smelling like gas. remember where gas comes from..... oil
Old Jun 24, 2009 | 08:00 PM
dawson89fc's Avatar
i am aware of the oil and gas coming from same crude.....lol...thank you all for your replies....aaron..... my exhaust alone will make the car pop as it does??? if you have time can you explain why??? also....are the tanks in the 7's baffled??? cuz if i corner aggressively with 1/4 tanbk or under it cuts out....if i have baffles would one be failing?
Old Jun 27, 2009 | 04:05 AM
dawson89fc's Avatar
OH
I really dont understand alot about the rx7 yet.... I know i love my car and want to know more.......
Old Jun 29, 2009 | 10:16 AM
Aaron Cake's Avatar
Engine, Not Motor
I am assuming the exhaust has eliminated the cats. Without them, afterburn will be much more noticeable. Especially if the air pump is removed.
All the RX-7 tanks are baffled but if yours is sucking air under hard cornering, yours may have come loose.
lt1_rx7
Blue Ridge Rotary Run
46
Oct 9, 2015 03:11 PM
cdn
14
Sep 10, 2015 06:23 AM
Marty RE
Aug 13, 2015 11:19 AM
