What is porting?
Old Apr 28, 2009 | 06:30 PM
fcs3l0ve's Avatar
No Pistons!
Question What is porting?
I sort of understand it and I've read you can do it to N/A engines. I'm just pretty unsure of what is... help? haha
Old Apr 29, 2009 | 05:31 PM
NA87FC's Avatar
jungle
your engine has intake and exhaust ports, holes that allow it to breath. porting is when you make those holes bigger. this allows it to breath better. you CAN go too big though. and keep in mind whatever you take off you can't put back. when it comes to rotaries the are different kinds of ports.
street port- pretty much you just make them bigger.
bridge port/half bridge port (i think they're the same thing)- you actually add a port under one of the intake ports (another hole), but so close that it leaves a "bridge" in between them.
peripheral port- i don't really know a good way to explain it. i think it's the like 12a with the ports entering the rotor housing from the end instead of around the sides of the rotor? i could be wrong though.
Old Apr 29, 2009 | 06:33 PM
Scrims's Avatar
Hide the pinball machine
http://www.rebuildingrotaryengines.c...rting_overview
Old Apr 30, 2009 | 09:05 AM
Aaron Cake's Avatar
Engine, Not Motor
Also, if you search the new user forum for "porting", you will find this question has been asked and answered many times.
iamsisyphus
Sep 27, 2015 01:42 PM
josef 91 vert
14
Sep 17, 2015 09:22 PM
