Did I need to index my pressure plate?
Old Apr 25, 2009 | 11:18 AM
Tom Deutsch's Avatar
I'm replacing the clutch on my 85 GS. Using a Daikin kit from RB. Comes with a new pressure plate. After I removed the old pressure plate, I crawled out from under the car and looked at the manual and it said I should have indexed the location of the plate on the flywheel.
Am I screwed? Or does this not apply when replacing the pressure plate with a new one?
Old Apr 25, 2009 | 01:25 PM
Sgt Fox's Avatar
Stigulus Moderatorai
Don't worry about it. What shape is the flywheel in? You probably should get it machined.
13
Jan 9, 2018 11:19 AM
t-von
Sep 10, 2015 01:56 PM
