12a engine wiring help for Lotus seven project
Old Apr 24, 2009 | 08:15 AM
LotusSeven12a's Avatar
I am building a lotus super seven that uses a 85 12a car for the donor car. The car ran great a week ago and now i have pulled the motor and installed it into the lotus and i need to know what is the bare minimum to make the motor run. I think the coils need 12v constant but as far as the ignighters go i am lost. i would like to not use the factory harness because it is in bad shape and plan to wire the sensors for temp and oil pressure myself. I just need to know how to make the distributor work, is there a box i need to wire? any help would be greatly appreciated, Thanks
Old Apr 24, 2009 | 12:48 PM
Aaron Cake's Avatar
Engine, Not Motor
All you need is the dizzy (ignitors are on the distributor body) and the coils.
You'll find the factory service manual in the 1st gen FAQ which will give you a wiring diagram.
Old Apr 24, 2009 | 06:39 PM
thank you so much for the help. i was worried i would need some kind of box or ecu. again, thank you
Old Apr 25, 2009 | 09:51 AM
Aaron Cake's Avatar
Engine, Not Motor
Nope. The ECU (really just a collection of simple circuits and relays) is only for emissions purposes and won't be of any help to you.
Old Apr 26, 2009 | 03:28 AM
ok, i looked for the wiring diagram in the FAQ and the link to wankel.net wont work i tried from different computers and tried to find it online and it eventaully always comes back to wankel.net and the site won't work....
Old Apr 26, 2009 | 10:38 AM
Aaron Cake's Avatar
Engine, Not Motor
Sorry, I don't know where else you can get the manuals. I almost always just refer to the Haynes. Worst comes to worse if you can't find it, I can post the schematic from the Haynes for you.
Old Apr 29, 2009 | 10:05 PM
ok, i have looked high and low for 3 days and can find nothing. I just need to know how the battery, alternator, ignitors, and coils are wired together. i hate you buy a service manual when the only part of my lotus that is rx7 are the items mentioned abovei really appreciate your help with this and i would totally understand if it is too much of a pain to post the diagram or verbally describe how to wire the ignition. Thanks again
Old Apr 30, 2009 | 09:04 AM
Aaron Cake's Avatar
Engine, Not Motor
I'll see about posting the schematic from the Haynes at some point.
Old May 2, 2009 | 09:51 PM
boyee's Avatar
keep it original!!
hope this helps with your project! http://foxed.ca/foxed/index.php?page=rx7manual#firstgen
cheers
Old Sep 24, 2010 | 02:57 PM
red bull's Avatar
I know this is an old thread, but I am also building a Lotus 7 with a 12a and just pulled the engine, so now it's time to install a minimal electrical. As I understand, once the coils are energized, a (30 amp) momentary switch to the starter silonid (sp?) shoud start the car. A simple alternater look to the battery will complete the circut. Now that's what I am hoping so perhaps you can enlighten me. The OEM schamatic is NOT useful as ALL emissions and accessories will not be used. Bare bones engine is all I'm liiking for! Thanks... I will cross post this on the LOTUSUSA.COM website as others seem to have this issue as well
~ John
Sonoma, CA
Old Sep 26, 2010 | 10:44 AM
Aaron Cake's Avatar
Engine, Not Motor
The OEM schematic is fine, just ignore all the emissions stuff. It will tell you how to connect the coils and ignitors.
Old Sep 27, 2010 | 11:37 AM
red bull's Avatar
Thank you, n\but the OEM has way to many accessories, and p\statsus sensors so I am still looking for a engine only wire-up.
streetlegal?
Mar 17, 2022 02:46 PM
befarrer
Microtech
Aug 22, 2015 05:52 PM
Professorpeanutrx7
Aug 15, 2015 01:38 PM
