too many gauges!
Old Apr 22, 2009 | 04:55 AM
floatyghosthat's Avatar
too many gauges!
Alright,
So, I'll be getting my FD in the next few weeks, and the first thing I'm working on is gauges. Reliability is goal #1, and the best way to stay reliable is to know what's going on, i.e. gauges.
I've been looking through the posts, and looking at the recommended gauges and have come up with this so far;
Boost gauge
Wideband A/F
Coolant temp
Oil Temp
dual EGT gauge
Battery Voltage
and many more....
So, here's the question: What the heck do I do with all these gauges?
I've already got Dephi boost, coolant and oil temp gauges, and want to get some more, but I'm going for looks over power and really don't want the interior cluttered. I've got a full size stereo with no room for gauges in the center console, and don't know where else to put them.
So, how many gauges do you have? And where did you put them all?
Thanks!
Old Apr 22, 2009 | 01:24 PM
Rx7_Nut13B's Avatar
Red Neck Tony Stark - C2
The only Gauges you need to be Reliable on a Stock car are the following
Boost gauge
Coolant temp
Oil Pressure
I currently have 5 gauges plus the ones on my laptop if needed
3 Gauges on the A-Piller
Coolant Temp
Boost Pressure
Oil Pressure
2 Center Speaker Gauges
Wideband
Oil Temp
Laptop Gauges thru Datalog
Rotor 1 Pre-Turbo EGT
Rotor 2 Pre-Turbo EGT
Post-Turbo EGT
Exhuast Pre-Turbo Pressure
Fuel Pressure
Old Apr 22, 2009 | 01:53 PM
Aaron Cake's Avatar
Engine, Not Motor
I'm going to add another to that list: fuel pressure.
Many of those gauges you won't look at very often, so they can be tucked out of the way. I look at basically three gauges when I drive the car; boost/vac, AFR, tach. Thus the boost and AFR gauges are on the A pillar, tach in the stock cluster, and then other gauges are off in a pod above the idiot light cluster.
Depending on what EMS you are going to run, a lot of those gauges can be eliminated and just logged by the EMS.
Old Apr 22, 2009 | 09:03 PM
I've got Power FC. Still learning about it, but hopefully it will eliminate a few superfluous gauges.
The1Sun
Sep 18, 2015 07:13 PM
kryan9
Sep 15, 2015 10:11 PM
The1Sun
Sep 15, 2015 04:45 PM
The1Sun
Sep 7, 2015 10:21 PM
