Power FC New PFC
Old Apr 20, 2009 | 03:05 PM
supranak's Avatar
RI New PFC
Hello,
I just bought a PFC and commander from a member. He had it in a single turbo application, and I am not at that point yet. I have stock twins, rx7.com SS DP, and Blitz CB. I do not have a datalogit yet, so is there a way to reset back top the base map and learn the idle setting?
Thanks
Old Apr 20, 2009 | 06:40 PM
Banzai-Racing's Avatar
Rotary Specialists
Go to "etc" and choose "all data init" this will reset the PFC to the factory setting.
Download the PFC commander manual from Apexi website it is page 38
http://www.apexi-usa.com/pdfInstallation/12.pdf
Old Apr 21, 2009 | 11:46 AM
cewrx7r1's Avatar
Eye In The Sky
Also find the URLs in the forum and download the manual.
Old Apr 21, 2009 | 03:43 PM
supranak's Avatar
Thanks Guys
Old Apr 21, 2009 | 03:45 PM
supranak's Avatar
Once I reset, do I have to make any changes with the setup I have?
Old Apr 21, 2009 | 08:31 PM
RotaryBuddha's Avatar
CURVE OF CONSTANT WIDTH
You need to go through the relearn idle process after the reset.
Old Apr 21, 2009 | 08:34 PM
" Start the car without any lights or AC on - switch everything off. Start the car and let it
idle for 10 minutes. The idle might be rough, but should smooth out as the PowerFC
learns the idle. Turn the rear window defrost on next, and let it idle for 10 minutes -
again, the idle might be rough for a bit. Then, switch off the defrost and turn the AC on
for 10 minutes. After that, the PowerFC should have learned your idle setup and is ready
to go."
I can't remember who to give credit for this, but it was someone on the forums here.
Old Apr 23, 2009 | 06:04 PM
mattmarrx3's Avatar
a mate just his p fc for his bat and the plugs are way to big to go into the computer he orded a computer for a 97 fd3s whan i had a look at the chassis tag its got e- fd3s does this mean anything when ordering the computer ?
he has 3 or 4 white plugs comming out of it and its is diffrent from out s6 (nearly got a free computer for our car lol)
any help would be great
Old Apr 24, 2009 | 04:03 PM
kru510's Avatar
will not fit ...you need one for a 93 or try to find an adapter
Old Apr 25, 2009 | 07:21 AM
Rx7_Nut13B's Avatar
Red Neck Tony Stark - C2
That is a 16-Bit model 96-02
93-95 are 8-Bit Models
Einheri
Oct 7, 2015 12:23 PM
baix2
Power FC Forum
Sep 28, 2015 09:40 AM
RE-Mamamia
Sep 11, 2015 02:13 PM
