what sensor is this?
Old Apr 16, 2009 | 05:33 PM
thejallenator's Avatar
its the little one here in the picture. it has a yellow wire with little red stripes on it. it leaks like a b word and i need to fix it. any sugestions on how to make it stop would be greatly appreiciated. its a 87 n/a 13b
Old Apr 16, 2009 | 06:07 PM
IanS's Avatar
Ricer
Coolant temp sensor. You can buy a new one (should come with the brass crush washer) from dealer or mazdatrix.com
Side note: The weird looking mushroom shaped (kinda) thing next to it is your oil pressure sensor. Just an FYI
Old Apr 16, 2009 | 10:11 PM
should the coolant temp sensor leak oil? because that lookst like thats where all the oil is coming out of. thanks for the info on oil pressure sensor. learned that one from lookin at the black dragon magazine
Old Apr 17, 2009 | 11:19 AM
another7driver's Avatar
Listener
That looks like coolant to me. Are you sure you don't have two separate leaks that are pooling there?
+1 on replacing coolant temp sensor. Use teflon tape.
Old Apr 17, 2009 | 01:36 PM
thats a possiblity. ill pull both sensors and stick some teflon tape on them and see if that fixes the problem. idk i just hope its nothing to major. hopefully the tape will fix it
Old Apr 17, 2009 | 02:10 PM
RotaryRocket88's Avatar
Top Down, Boost Up
If you're leaking coolant, the coolant temp sensor is leaking.
If you're leaking oil, the oil pressure sender is leaking.
Old Apr 17, 2009 | 02:27 PM
Aaron Cake's Avatar
Engine, Not Motor
Oil leaks could also be the o-rings from the filter pedestal.
Don't use Teflon tape on the coolant temp sender. Use pipe dope. Teflon tape can insulate the threads and make the gauge act wonky.
Old Apr 19, 2009 | 04:36 PM
fyi. the easiest way i found to remove the coolant temp sensor was to first remove the oil pressure sensor using a 14mm end wrench. then take a 12mm deep socket with an extension to remove the coolant temp sensor. worked out to be fairly easy.
killerrx710
Sep 28, 2015 09:13 AM
killerrx710
Sep 24, 2015 10:57 PM
rotor_veux
Sep 19, 2015 07:13 PM
