Differential Mount Questions...
Old Apr 13, 2009 | 10:55 PM
streetwize's Avatar
Question Differential Mount Questions...
My brother and I just bought and 87 rx7 and it has a problem in the rear end. Anytime you shift gears there would be a thud sound in the rear. Had been told it was the differential mount and that it was snapped off the sub-frame. So do we need to replace the whole rear end or just the mount. It is a stock rear end, we would actually like to upgrade.. any suggestions that are economic
Old Apr 15, 2009 | 02:14 AM
Rx7_Nut13B's Avatar
Red Neck Tony Stark - C2
THe read end has three mounts, two in the back and one in the front, the front one is just two metal blocks with a rubber part between them, the rubber normally breaks down.
You can just replace it with a solid mount.
The only real upgrade is a TurboII rear end but then you have to change everthing to make it work.
Unless you are installing a turbo or using the car for ALOT of drag racing then you will be fine with the stock NA
freq
Sep 7, 2015 04:35 PM
SakeBomb Garage
SakeBomb Garage
Sep 4, 2015 05:20 PM
SakeBomb Garage
Vendor Classifieds
Sep 4, 2015 05:19 PM
kkev.7788
West RX-7 Forum
Sep 2, 2015 02:13 AM
