Vaccum line, oil pressure question
Old Apr 13, 2009 | 06:08 PM
Bwek's Avatar
High Comp Booster
ON Vaccum line, oil pressure question
hey what kind of oil pressure should i have at idle?
^^^ and that line where is that supposed to go? its to the immediate right of the intake manifold when standing in front of the car
its a 91 N/a car
thanks guys
Old Apr 13, 2009 | 08:22 PM
RotaryRocket88's Avatar
Top Down, Boost Up
It should be around 30 psi at idle. But the stock oil pressure senders aren't exactly reliable.
Download the S5 factory service manual (FSM), and take a look at the vacuum diagram in the fuel & emissions section to find where that line goes.
Old Apr 13, 2009 | 09:55 PM
Bwek's Avatar
High Comp Booster
ya i found that part out about the vacuum line
but as far as oil pressure goes on my cluster? what should it show or is it not accurate
Old Apr 15, 2009 | 02:16 AM
Rx7_Nut13B's Avatar
Red Neck Tony Stark - C2
at idle it could not even show anything, like he said above, there not reliable. You will need a mech gauge to really tell what is going on.
20psi is about the lowest I have ever heard of, with 60psi being the top at Idle
Old Apr 17, 2009 | 02:39 PM
Bwek's Avatar
High Comp Booster
alright thanks guys
andyvideopro
Aug 20, 2015 10:55 AM
20B Forum
Aug 18, 2015 02:46 PM
