Having Trouble with my 87 RX7
Old Apr 13, 2009 | 05:56 PM
rotaryguy481's Avatar
Angry Having Trouble with my 87 RX7
I cant get it started i have even tryed poping the clutch anyone help me
Old Apr 13, 2009 | 06:41 PM
Aaron Cake's Avatar
Engine, Not Motor
Check for fuel.
Check for spark.
Check for compression.
Are you missing either one?
Old Apr 14, 2009 | 03:03 AM
kingofcatastrophes's Avatar
i have the same problem on my 86 gxl sometimes. pull the fuel injector fuse, crank the engine for 10 seconds with the gas to the floor. put the fuse back in and it should start right up
Old Apr 16, 2009 | 03:10 PM
fixed
i got the car running yesssss it was the mass air flow sensor gay lol runs good but does anyone know where i can get a Diff Mount at or anyone got one for a good price all the ones i have found have been like $240 bucks so i dieing here lol
Old Apr 16, 2009 | 04:18 PM
another7driver's Avatar
Listener
Mazdatrix has the front diff mount at 160+shipping, while the rears are 80+shipping each (two required). Used ones should be easy to find in the classified section if you're willing to chance it. Installation is simple but time-consuming.
*edit* Competition mounts are significantly cheaper if you're willing to deal with the stiffer rubber.
Daua118
SE RX-7 Forum
Dec 5, 2021 04:15 PM
Junkee
Aug 15, 2015 01:57 PM
Marty RE
Aug 13, 2015 11:19 AM
