85 12a needs Help
Old May 27, 2002 | 04:50 PM
Question 85 12a needs Help
I purchased a 12a that I was told was running good & strong when it had been removed(was replaced with a V8), it had been sitting for about 6mths outside under a cover. When I finnished installing it, it would not start so I gave it the ATF treatment. Engine started first time BUT.........
#1 it will not idle under 1500 without stalling,
#2 refuses to restart when hot. When I first started it up I did not disconect the exhaust, I did shut it down & disconnected it but now my cat is glowing!!! I have done the following.
1. Compression seems to be around 55 on all 6 seals.
2. I double checked all pipes for vacum leaks(wd40) & found none.
Any suggestions as to how I continue.
Many Thanks
Old May 27, 2002 | 04:52 PM
BTW. it starts fine when cold or when its had time to cool off.
Old May 28, 2002 | 05:23 AM
Hey I really need help.............................
Old May 28, 2002 | 05:33 AM
Aico's Avatar
I'm no expert, but I think you're compression is to low
Old May 28, 2002 | 08:01 AM
damon's Avatar
have you tried to rebuild the carb?
have you checked your timing?
your cat is glowing because it is now clogged , disconnect and make a "test pipe" to fit where they were.
the compression is low , but it is also steady so you should be fine
peace
Old May 28, 2002 | 08:34 AM
Thanks. I guess i'll go get a timing light & check the timing. Would this cause the engine to not start when hot???
Old May 28, 2002 | 08:46 AM
yayarx7's Avatar
Are you Nucking Futs?
bad timing makes it difficult to start, it will give the combustion chamber the spark at the incorrect part of the rotation of the motor, sometimes firing against the rotation, sometimes right out the exhaust.
Old May 28, 2002 | 08:58 AM
Directfreak's Avatar
I am a Jeeper Now.
Re: 85 12a needs Help
Many Thanks
You Did the ATF, and Ran it without removing the CAT?
If so, you probably ruined it and clogged it. You're supposed to remove it when "cleaning it out" after an ATF Treatment.
Do as it was recommended earlier, and replace the cats with a "test pipe" to get it running. You Really have to drive the car on the highway (smoke filled-high speed runs) to get it really cleaned out.
Your compression does sound low, but that could be because either it's not cranking fast enough, or because the seals need to expand after sitting so long.
Start it, and drive it on a long (preferably deserted) stretch of highway, keeping the RPM nice and high.
Courtesy of V8Kilr
Old May 28, 2002 | 09:42 AM
I know should have removed it Will let you know what happens after I redo the timing. I did notice yesterday when I took it for a run that it was acting rough on acceleration, & yes plugs are clean & fuel filter is new.
Thanks. I really need to get to the bottom of this, else the wife says car has to go !!!!!!!!!
Old May 28, 2002 | 10:40 AM
hanman's Avatar
Make sure that you have good plug wires too.
hanman
Old May 28, 2002 | 10:42 AM
I have new wires,dist cap,dist rotor,fuel filter.
Old May 28, 2002 | 03:29 PM
85RX7GS's Avatar
It's the timing most likely that's not allowing it to idle. Also, the ATF will kill your cats and they are probably clogged from all that gunk.
Old May 29, 2002 | 05:26 PM
Today beat the **** out of the inside of the cat & put it all together, sounds & feels alot better( dont have emissions around here!). Tomorrow will do the timing.
Old May 29, 2002 | 05:44 PM
85RX7GS's Avatar
You don't have emissions in Reading? Several of my relatives in PA have to get their cars to pass smog, but they are in the Phili area. Was this just recent that emissions were cast away?
Old May 29, 2002 | 09:32 PM
Berks county (Reading) is one of the few that has never required it :
Guess I can't move............
Andrew7dg
Aug 6, 2017 01:41 PM
rx7inoregon
Old School and Other Rotary
Oct 1, 2015 12:44 PM
